Greavesy
380
Donny
Stated noticing that dropping from 3rd into 2nd is getting pretty difficult.
Do you think a linkage reset will help it out or is it something more serious?
Only noticed it driving this week.
Dave_c85
395
N249 bypass and ditched my s2000 cone for a Jetex. Not sure I like the sound yet with n249 bypassed but I'll see how it goes
Sent from my C6903 using Tapatalk
FrixosLeon
68
Guys I discussed the N249 bypass mod with my mechanic who is doing all my mods up to now (APR specialist as well) and he is strongly against that mod.. what do you gain by doing it??
Sent from my GT-I9195 using Tapatalk
Dave_c85
395
Haven't noticed any difference really yet, dv is a lot faster though. Gonna do some logs later to see how boost is holding etc
nathan_20vt
365
Kings Lynn, Norfolk
:censored:Decided to breakdown. Went to change gear and pedal stayed on the floor. Pulled over further up the road to find clutch master cylinder has split and was pissing brake fluid all over my hot manifold. Just what I need :censored:
csd_19
2,279
28
Angus / Edinburgh
Wouldn't hurt to do a linkage reset, do you have any issues with 1-2? How many miles on the car, do you know when the gearbox oil was last changed?
Greavesy
380
Donny
Nah 1st is fine and going from 1st to 2nd is sweet, its just dropping 3rd to 2nd thats the issue. All the others are fine. Mileage is 87k. I changed the gearbox oil about 2k ago.
useyourname
322
In a shed
It seems that we have a joker at my workplace :lol:
dee150
Fitted a new Coolant Temp sensor,god knows how you are supposed to change it without loosing the coolant,ahh well she has new coolant now too :D
Greavesy
380
Donny
There's a drain in the bottom of the Rad. drain the coolant into a 'clean' bucket. When you're done pour it back in through a fine sieve (sp?). Walla!
Realize it's too late now but meh! Just thought I'd say.
nd-photo.nl
3,668
22
The Netherlands
www.nd-photo.nl
I had an even better fail! I forgot to unscrew the cap of the expansion reservoir, so the system was still under pressure resulting in a coolant shower hehe
(Was working on n112/n249 delete and replaced the coolant neck)
markpile
Wolves till i die!!!!
Mar 15, 2014
434
Wolverhampton
Fitted cold air intake pipe filter is in place of 2nd ic on an lcr and before the criticism starts there is an aluminium 45 degree bend on its way and a shield to stop water ingress in filter
Sent from my C6603 using Tapatalk
