Earlier in the week picked this lot up (leons are actually quite big when empty)
Set of slicks and wets on supercopa race rims. Also got a baffled sump same as the seat sport ones.
While stripping the back end to do some electrical fault finding I compared my spare that never fitted to ones on the car to show hoe heat and lack or waxing has killed the candy
The quicker/more simple N249 bypass mod!
Got rid of the HUGE split pcv pipe and fitted a catch can. Now I'm left with a couple of very scratched hands and a dangling relay box, what have you catch can guys done with the relay
Take out your air filter and take off the top of the black cable trunking the relay fits inside then just put the cover back on
How does the relay come out of the box though, mine seems completely sealed in, have you cut the plastic box away?
the wiring block slides into the housing there is a small tab you pull back then the block will slide out of the housing
i have a snow performance stage 1, activate by boost switch. I install my self, i have a car shop. Also install a selenoid upgrade.
I've done a n249 bypass but can't upload the pics till I make 15 posts or more. Quite easy
Cleaned and polished the car, tried out the bilberry wheel cleaner and very happy with the results.
