What did you and your MK2 do today?
Daniel M
Blackbelts & Chickenheads
Apr 18, 2013
2,874
7
Middlesbrough
New tyre today. It has sorted the noise on the o/s front as it was missing a wheel weight, but is now fully balanced etc.
Once its had its re-test I'm going to have the alignment done.
Alzak
666
Not as bad as i thought once dropped on the ground.
Do you get some rubbing when you go over speed bumps ?
Crafoo
Crazy Fool!
Apr 30, 2005
5,498
At home
Bought some rubber edging for the Revo heat shield to protect the ceramic pipe from damage, the current foam that's applied to the pipe is starting to lose the battle to the heat lol.
Sent from LG G2 using Tuppytalk
