How do I find out what gear box I have?
If you have a cupra R with a FZQ gearbox the shim will work
Are the pre 2003 gearboxes without the inspection hole a compleatly different box? Or if you removed the outer metal casing on the end can you fit the shim?
does anyone actually know how much end float the shaft is supposed to have or is everyone just fitting the same thickness shim and hoping for the best?
