Looking at getting a clay bar so I can give my car a thorough clean. But I'm stuck. Do I get fine or medium clay?
I'm confused lol
Sent from my SM-N9005 using Tapatalk
If you have never clayed before then I would go with the medium clay that will get most of the stubborn tree sap spots off and tar.
Once you get into the a good cleaning routine then you can use a finer clay.
The meguirs starter kit is a good kit , just be aware that once the detail spray is empty you can use water as your lube , does exactly the same thing.
