What did you and your MK2 do today?
Jimbobcook
6,160
2,540
Indeed. He didn't enjoy doing it. To be fair to him he did persist and do the job, though :)
If this light pops out while it's being driven I'm going to go to halfrauds and pull up a chair... If they do it in under 5 minutes I'll buy them lunch lol
Sent from my iPad using Tapatalk HD
Kevgrady
420
North East
Fitted my coilovers tonight.
WeeG
3,407
Largs , Ayrshire
Well!! Back to stans rollers and had another terra clean. Stans are know as heartbreakers and here's a new record for stage 2+ cars on his dyno
Really happy with results especially considering Stan rarely sees over 360 on his rollers on 2+
Car is away in for a timing belt and water pump
Jan 3, 2014
593
These are awesome results mate. What have you done to the car? If you don't mind me asking
Sent from my SM-N9005 using Tapatalk
WeeG
3,407
Largs , Ayrshire
Here's the list bud
Revo stasis intake
NGK iridium 7,s
Autotech HPFP
Rs4 fuel pressure valve
Full 3" Miltek decat
Neuspeed turbo discharge pipe
Neuspeed throttle pipe
Eurojet stasis intercooler with air con delete
Rev G DV
Cold air feed
SPEC stage 3+ SMF clutch
WAVETRAC limited slip differential
THS engine/gearbox mounts
Forge short shifter
Super pro anti lift kit
VWR 360mm 4 piston big brake kit
Bilstein B12 shocks
Eibachsportlines
BHS front and rear ARB's
Pro race 1.2 18" alloys and r888's
Jan 3, 2014
593
Here's the list bud
Revo stasis intake
NGK iridium 7,s
Autotech HPFP
Rev G DV
Cold air feed
Forge short shifter
Bilstein B12 shocks
Eibachsportlines
Not bad, not bad
I'm actually really jealous. Wish I had some kind of funds for this kind of work. But slowly but surely.
Feb 6, 2014
1,323
Lincoln
It's a joke! They would charge an hours labour to change a bulb I bet! That's £50+
I was so angry at myself for not being able to do it that I checked YouTube and it seems on a Megane it takes a green flag man 45 minutes to change 1 bulb and a normal human 53 seconds to change a golfs...
I don't see how removing the bumper would help the dipped beam is 2 inches away from the fuse box which isn't moving lol
It took 3 mechanics an hour to change the dipped beam and the side light on my old Pro_ Ceed. I was abit embarrassed about having to get them to do it, but I almost had no knuckles left.
Changing the bulbs on the MiTo is child's play though.
Penguin
143
Just updated my rather limited RR thread with these changes
Finally got hold of facelift heater control panel. One of my major gripes with car was having to continually pressing those buttons to adjust the temperature.
Sprayed the door trim panels gloss black.
And finally a nice little touch on the boot badge to go with the yellow black theme on the wheels.
holmefield
Forever messing with cars
Oct 20, 2013
578
Rob_Talismarch97542 said:
Found a place i can get my 3sdm 18" in 8.5 front n 9.5 rear. Would this be a problem? Was going for 8.5 all round
It all depends on your E.T ( offsets ) my 8 x 18" all round are E.T 30 front and 25 rear which is quite low for leons.. my fronts just catch the inside lip of my arches going over speed bumps @ say 20mph..but are fine for everyday driving..my rears just clear and I do mean just...im going to 215/40's on the front ( currently 225/40 ) which should Clear the inner arch lip...
