Water leak into footwell - dodgy seal info and DIY repair guide (Image links dead)
1986brandon1
151
Chester
Socket would be much easier^^
Finally did mine at the weekend and it really isn't that hard, will look at the passenger side when I next get a chance even thou it's not leaking. Yet.
Had some rain last night and had perfectly dry door sills this morning. :)
Dougster
158
Clydebank, Glasgow
UPDATE:
I done mine today!!
I found out the rear offside seals had been previously botched with silicone and I couldn't get one of the front passenger T20s out (that side is bone dry anyway but will drill it out next time car is on a ramp)
All in all pretty simple but I WOULD recommend a heat gun to help get rid of the rotten seals and I had IPA to clean the metal too.
Another thing I haven't seen mentioned is the circular rubber speaker boots that no matter what I couldn't get back on the Blaupunkts. :confused::confused:
I only broke 2 door clips and everything seems to be snugly back in place and working.
PS I washed the car and ZERO water was getting in where it had been previously seen.
I'll just need to keep sooking the residue way with my George Wet Vac but it wasn't that wet inside anyway.
Dougster
158
Clydebank, Glasgow
Has anyone completely removed a rear carrier plate?
The previous botched job has rendered my attempt useless and water is still getting in the back.
I'll do it again and clean all silicone which will be fun. :-(
Mar 7, 2011
582
Plymouth
I have yet another leak.
Pollen filter appears to be leaking, I'm not sure where fro. I though. I know it is seated correctly and I know the cover is also seated correctly but I'm still getting a drip in the passenger footwell.
Any ideas? Maybe remove the pollen filter housing and re-seal under there? Is that even possible?
Sent from my GT-I9300 using Tapatalk
Oct 15, 2013
926
Midhurst, West Sussex
Hi all I'm hoping someone can help me please. I've read the guide on pg 33 (thanks Steve) and think I've found the right bits but I'd appreciate if someone could confirm they're the right bits before I order them
Please could someone confirm for me :)
Pry tools
http://www.ebay.co.uk/itm/190703018205?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Clips
http://www.ebay.co.uk/itm/350347506040?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Sealant? Not sure if these are the same thing?
http://www.ebay.co.uk/itm/BOLT-ON-P..._Body_Shop_Supplies_Paint&hash=item4d16a7356f
http://www.ebay.co.uk/itm/BOLT-ON-P..._Body_Shop_Supplies_Paint&hash=item4d1604bced
Also if anyone local to West Sussex / Hampshire who fancies lending a hand please let me know as it's be very much appreciated :)
Thanks again
Ryan
Oct 15, 2013
926
That'd be awesome if you could. It's not exactly local (100 miles) but I'd really appreciate the help lol it's just getting the dry weather to do it unless you have a garage etc lol :)
If you let me know when's convenient I'll happily come over with beer tokens / applicable payment etc :)
Ryan
