ok cool I will switch the sensor first, and see if the actual matches up.
yea from what I read I kinda got the idea that if you adjust it the ECU tries to correct it anyway,
http://forums.fourtitude.com/showth...p-adjusting-my-fuel!-with-unisettings-that-is.
I was looking at post #23
I will replace o2 first do a another couple of logs then I might try some small adjustments to see what the actual fuel reading is and if it changes, this is just to make it safer though i'm not expecting more power from doing this, thanks again for you input.
