you took the words out my mouth there with regards to the clutch/gearbox not liking the mega power/torque. Thats why the 335d is only available in an auto.
sounds like you have done a bit of research with regards to mapping.
pix-n-mixwhat is your username on ebay?
Massive shame this is going, I learnt a lot from it and it was just as good in person as it is on here! Still my favourite tdi on the forum.
Sent from my iPhone
Make sure you get the odb port relocated and software upgraded. My 6 month old 335d was nicked a while back.
Yea was gonna say it's on my thread. Google search will bring up tons of stuff too.
Sent from my GT-I9505 using Tapatalk now Free
ok fitted my SFS intercooler and pancake pipes over the last few days.
The pancake pipe is bigger then the original which meant refitting the o/s splash guard that fits to the under tray near on impossible, but ive modded it to fit, as its all too close to one of the cambelt pulleys.
Its given me a right headache to do cause ive been getting boost leaks all over the place and ive put it down to the difference in O-Rings. I think for £250 its a joke that SFS dont include or put on the o-rings in the first place.
In the end ive used the green grooved o-rings from my old hoses and that seems to of fixed the leaking issues and the black round o-rings dont work at all. now less smoke boosting to 25 psi instead of 29.1 (TDI)
OK, finished building and install my custom air freshener system.
Bit silly i know but was bored with 6 weeks off work and with magic trees only lasting about 2 days thought i would design something. works well actually and love the Febreze Caribbean Paradise smell. Smelly farts in the car are a thing of the past
Parts Needed
Triumph Tudor 500ml washer bottle and stainless bracket - £15
Ring Automotive universal 12v screenwash pump -£12
5m clear 3.2mm washer tubing -£3
One way valve - £2.50
12v electric shut off solenoid valve - £12
1/4" BSP to 4mm Hose tail connectors x2 - £5
1/4" BSP Bonded washers - £1.50
Push to power switch - £2
5m 25amp red power wiring - £3
Various spade connectors and terminal blocks
2x 300ml Febreze Caribbean Paradise air freshener - £4
Febreze novel spray (taken apart from used Febreze can)
Total = £60
Vid in action
Thanks for the insight jonjay. Considering getting a tracker fitted I can monitor on my iphone.
