BoostHard
Complete Plonker
Nov 25, 2012
1,391
At Work.......
www.Passionford.com
Here you go.
Doesn't show that well in pics and I expect it will settle a bit as well.
Before..................................................After
Did you replace the topmount bush as well?
Thinking I may go for the 50/40 kit now. I'd want the front to sit a bit lower
MalcB
Quantock Hill Billy
Sep 13, 2011
161
Taunton
Yes the top mount and bearing were replaced. I agree the front is probably sitting a bit high.
40/50 would look better. However, where I live in the middle of nowhere down a farm track with a cattle grid, I'm glad it's no lower.:).
Really pleased with the handling though. It feels nicely planted and not too harsh. Turn-in is much improved.
Gingerbread Man
172
Gloucester
I think I have a coolant leak, hoe much do you think I'd be looking at spending to fix it, change cam belt, water pump and full service. Iv been given a rough quote at around £300, is that good value?
Sent from my Galaxy Nexus using Tapatalk 4
Gingerbread Man
172
Gloucester
That seems a bit to cheap for that lot,
where is the leak coming from?
I thought it did but still I don't want to be spending a fortune, the car already has had £450 repairs and it cost me £719 lol I'm not sure where the actual leak is coming from. I'm considering just putting in one of those rad seal type products and seeing how that goes. I think its a slow leak as I haven't seen any puddles under the car but the header tank is low and I had it topped up a couple of weeks back when my car was at a garage getting electrics looked at
akchappers
3,069
7
Gillingham Dorset.
Get the coolant system pressure tested mate. Can you not see any leak at all? Cances are it's either a pipe that needs nipping up or a slight drip from the rad. Although I did see a couple of people on here needing the coolant bottle cap replacing!
Ak
