Quite a big update.
Started ripping out the interior on Tuesday as the old roof lining had sagged something chronic....
Stripped the top half.
This is the colour difference between the two linings.
The finished product. Big thanks to seal, cupra barn and ronin for getting it all out of an LCR they're breaking!
Missing an a pillar due to a nomad pillar being rubbish. I'm getting a refund though and picking up a vent pod tomorrow.
Whilst I was at it I ripped the boot apart to fix this little buffer that has been popped for about 6 months, also changed the boot light bulb as the water that had leaked from the washer had corroded the bulb. This has solved my fuse blowing
problem when I open the boot
Also on Tuesday I had these taken off....
and replaced with 4 Goodyear efficient grip performances. £120 a corner fitted but at least they're the right size now!
I had them replaced due the the height and ride of the car with the 215/35/18's on, this is how low it was.
Bit of bad news however, the car stalled as I put the clutch in last night and would crank but not fire up. (Or compress up I suppose?) it was due to the silicone fuel lines I put on swelling and I king in air, and when I took the filter out to check it I thought I'd put the pipes on the wrong way so the engine was trying to use the return so fill the cylinders but obviously this wasn't enough fuel. However looking at photos I think I may have got them mixed up when I fitted them :/ anyway, the engine doesn't stutter under hard acceleration anymore
Car got recovered to mine last night, then recovered to SEAT this morning where they diagnosed a fuel
problem and fixed it, but they washed the car too! So a £65 car wash!
And today, because I had no car I thought I'd get in with some stuff I've got to go on the car.
Re did the engine cover in plastic dip to practice, quite happy with it!
Now I plan on doing the expansion bottle and the washer fluid bottle in the matt black too.
And the best bit, I gave the brembos a lick of paint, only a quick refurb as eventually I'll get all new seals etc.
Also did the middle of the discs as they're off the car and pretty rusted.
I'm going to sell my 225 steering wheel in order to get an r32 one, always wanted an r32 but I'll have to do with just the steerer!
Cheers for looking.
Sent from my iPhone
