To cut a long story short a mate forgot to tighten the bolt holding the crank pulley on when replacing the cam belt for me. ...It all fell off.
I was almost stationary when it happened (barely over 1000rpm), so he reckons it's not as bad as if it had gone at 40mph.
Now it is running very rough, and will only start without the air box fitted. Sometimes nothing happens when the accelerator pedal is pressed and you have to switch it off and start it up again without the air box on. My mate insists it's all timed up correctly.
It has a new cam belt, water pump, oil filter, and oil
Any one got any specific ideas?
I have a reasonable knowledge about cars but I'm not an expert.
