LunaR
Thanks pete best £14 I've spent on the car. They were in abit of a state usual pink fade and lacquer peeling and bubbled up but I'm guessing it could've been worse lol.
Something that's bugged me since forever, had the inner ends of the side skirts sprayed once before but already they are sandblasted by the road rash, to permanently sort this I did this
Here's the issue
So I cut some templates and transferred to 2mm abs sheet and cut these out
Used some oe screws
Eh viola!
Takes the eye of the unsightly rashing, plastic will wear bit not as visible and looks loads better, I think anyway , done this both side obviously :)
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
Here's the issue
Used some oe screws
Eh viola!
Fancy making me some I hate mine for this!
Sent from my iPhone
Pete225
198
Mansfield, Nottinghamshire
Here's the issue
Used some oe screws
Eh viola!
Cracking idea that!! My side skirts look very similar, the yellow is being chewed away by the roads and almost black :/ lol
BreadlyBrown
281
Southampton
Washed, new R badges, de-badged 'LEON', new wheel centre caps, painted engine covers, fitted full set of blue/white headlight bulbs except fogs which I need to wait for my axel stands to arrive to get at them :)
Also booked in for 65000 mile service and new disks and pads all round.
Andrewcupra TDI
Resident Desk Jockey
Apr 30, 2008
3,282
in the mountains ( Wales )
tightned up my forge quick shifter,, bolt came loose and had panics that Gearbox was on way out struggling to get into reverse !!
suppose you dismiss bolts coming loose on cars , where as in motocross / enduro prepping bike for each race you always make sure everythings tight !!
also bought a 2nd hand set of injectors and tandem pump try and get htis car back to itts former glory
