I got a bit more done on the splitter tonight.
I've rounded off all the edges this
help the carbon cloth to stck in place as all it wants to do is lift and lay flat.
Marked out where the OEM splitter will sit so I know how far to go with the base layer of carbon
Next I coated all the edges with base coat epoxy resin to seal the edges, I then wrapped the lead edge in a base layer of carbon
I want to build up the lead edge as much as possible to prevent it wearing down too quick and exposing the ply, the clean resin is very tough so with 2 layers of carbon and a few coats of clear resin it should hold up pretty well.
Next stage will be to cover the rest of the under side with the "rough" carbon and then cover with clear resin.
Once that has cured for 24(ish) hours it'll be sanded down till it's nice and smooth and then I'll wrap it in the 2 twill carbon
