Not really updated this for a while so here goes!
Firstly, the car's running brilliantly. Really pleased with it and just been sorting out the little jobs.
Oil pressure sender was fubared. Oil pissing out of the top around the connector pin jobbie. I superglued it over Easter weekend until ECP was open on Tuesday and I popped down there and picked up a new one.
I also noticed the washers that were under it were mismatched and a bit old and probably create a few gaps.
I tried it without washers but I need a minimum of two thick ones for it to tighten properly. After fitting the new ones it was still leaking a tad so I wrapped a little PTFE around it and now it's bang on. Doesn't leak at all. So after a little research it turns out the washers there should be copper. If I'd had the proper copper ones then I wouldn't have needed any PTFE.
The only thing that's wrong with the car now is I've been having a bit of trouble with my offside engine mount. It's still the original part, and since I've replaced literally everything else on this car, I've forked out for a new one - well I say new, but it's discontinued everywhere so I've got a nice 2nd hand one for cheap. It just got here the other day, no pics yet.
I bought new poly mounts ages ago for when I did the conversion, but when it came down to it we didn't have time to do them so they're still sitting here untouched.
So why buy a new mount when you have a poly mount set at home?
This is why:
Need the metal bit!
I should get those swapped this weekend and then the car will be back to 100%
Gave her a bit of a clean the other week and snapped a few pics:
The mats were DISGUSTING!
I've not really spent any time on them since I bought the car, I was always planning on getting new ones, but the more I look at them, the more I like the original ones.
So I dug out some product and gave them a good going over.
Just another little detail, but they make a big difference to the interior.
Then I took the car down to AmD Essex for the SCN rolling road day. Needless to say I think I surprised a few Cupras
Ended up running 131bhp but I can't remember the torque. I've got the graph somewhere and can scan it in later. It was a nice linear shape with no bumps so that's what matters really. The car is running great now, no more smoke - I've put that down to the fact that I was running no filters on the carbs (got some now - which might explain why I've lost 3bhp) but she pulls like a train and isn't smoking so I don't even think I'm going to bother with a compression test. I can assure you 130 odd bhp is plenty in something that weighs 750kg!
Here's a quick video of it on the rollers - not very exciting tbh.
Dyno Video
And then the other day something happened when I was browsing ebay. Wheels.
The Compos really are sooo right for it, but I've had them on for a few years now and fancy a change. Thanks to a poorly written listing I was the only bidder!
They're off a Lotus Esprit S1. They're 4x100 with a 57.1 CB so will bolt right on. Only trouble is the rears are VERY negative offset! I'm chatting to a good mate of mine at the moment about narrowing the rear beam.
Stay tuned!
