blackrat250
15
Hey Folks,
Thought id introduce myself.
Im Dave from Partsulike and wanted to come on here direct with a couple of you emailing re the LED KIT upgrades we do and the number plate lights and causing error messages. It appears this is an issue for the face lift / newer SEATS.
Ive spoken to our supplier and the canbus element is whats likely to cause the problems.
If i can try and keep it simple.
This is an example only and not necessarily the correct figures.
If the rear bulbs use 10w of power then anything below that would create the error message. Meaning that there is a bulb out.
LEDS use very little power as you know and the canbus LEDS that we sell simply have a built in chip to almost trick the car into thinking the LED is using more power than it actually is. This creates quite a bit of heat.
Sadly the chip can only fool it into thinking so much power as it would get too hot. So for example. The car requires 10w. A normal LED will use 3w. A canbus LED will give an extra 5w making the total 8w. Meaning there is still a 2w shortfall. Thus causing the error message.
We have ordered some new chips that simply connect direct to the wires which are due in over the next couple of weeks. Ill try and get a picture posted up.
If anyone has purchased some LEDS from us and are getting the error messages from the number plates, please could you drop me an
email Dave at partsulike . co . uk
with your full name and post code so i can track your order with us. Id also be interested in the age of your car to see if it is the newer ones that are the problem.
We are currently having a new website designed and will make sure we distinguish between the two variants.
Regards
Dave
If im going to be honest i have no idea. I would presume so. Its a question i can take back.
It would be great if the built-in resistors actually can fool the car and make it think the LEDs are using 10W rather than 3 or even 8, however built-in resistors in small can-bus LEDs are pretty weak and have a short lifespan from my experience. I think the best option at the moment is buy actual resistors and install them along with the registration light LEDs.. not only is it cheap but also it's long lasting and the resistors can be replaced at any time. I guess the only downside is that some rewiring will have to be done. I guess facelift Leons' can-bus system is like a curse.
Have e-mailed you guys several times with no reply about this, I have purchased a premium kit
Just sent you another e-mail and look forward to some working LED's :)
LeonCR, just replied mate. Or at least i hope its you !
Olitaylor, glad to hear it mate. any issues let us know. Im hoping there shouldnt be !
Tarek, We are seeing a few going this way. Audis and Mercs in particular. These ones we are looking at getting simply require a splice type connector which are supplied with them. Thankfully there is no cutting or mass rewiring involved.
Dave
Yep that's me, i shall be the guinea pig on these and will let you all know ASAP :)
I am looking for number plate LED's, i've tried 3 sets from various eBay parties without success. Are these ones likely to work?
Hey Folks,
Regards
Dave
06 TFSI Sport Leon Pre-Face MK2
Brought a set awhile ago now and Dave kindly offered an upgrade to test out new bulbs everything worked perfectly no faults as of yet...
Many thanks
Emailed. Hope you can get it sorted as the rest of the kit I bought has been faultless!
I had no problems with mine. I have 2010 ecomotive, and I know the electrics are different due to Start/Stop and regenerative braking on the car. I've found quite a lot of lights that error for other people don't error for me.
do you have xenon's, my thought is it seems to be mainly people with them that have issues
I have a 58 reg with xenon's tried a few bulbs from ebay and bulb failure comes on everytime. Apparently error free canbus friendly. In my case I don't think so. If these will definetly work then I will buy them.
