Mk1 banana
334
(Not so) Sunny Hastings
Changed inlet manifold, (inc injector seals, tb gasket...) so I could do away worth the self tapper in the mani, and 't' Piece in the fpr (vac) hose.
so much more responsive now, after a few coughs and splutters!
Re scanned and no faults at the moment:) hopefully fit for the map on Saturday morning now...
joshy514
Fleet Air Arm by ability.
Mar 2, 2012
1,836
Gloucester
www.seatcupra.net
What a day! struggled with a mate taking out the gearbox to do the new clutch and dmf, then tried taking the turbo off!! How much of a bitch is the access to the spring clip on the TIP (fr150)?? took me about an hour haha! All out now, new clutch lined up and ready for the turbo to be picked up, reconned and sent back then box back on and bed in the turbo!
Feb 22, 2009
3,618
South Wales
this is to be rewarded with a full service and belt change this weekend
SimianWonder
Bought a new "R" badge for the rear of the car as the old one had faded somewhat and it made the car look older than it is.
mill5y
190
sheffield
You dnt have a link or part number for the bearings do you?? Are these parts all universal across golfs/leons etc, is it very hard to ordr wrong parts??
supersticky
1,014
46
taunton somerset
Finished the quad mod :) and sorted wiring, even thou I'm a little concerned as they are all bright but all are only 5w bulbs!! Still well happy with it :)
stupot_1982
270
Spent a few hours this morning fitting a CM TIP. After much swearing and hamering (gently) I got the adapter on. It was tighter than a fishes **** then chopped up the TIP to make it fit;
Have I done it right?
Also adjusted handbrake as it was only pulling on one side, then hoovered and polished inside. Time to give it a shower... Ready for RR tomorrow
marcus.l
168
Manchester
Yer looks right to me.
