Got more done on Monty, First off get the bottom end out..
Stripped down...
Early crank which I forgot I fitted...
Shame to say good bye but onwards and upwards
To comfirm the changes to the bottom end are:
Over bore to 87mm
Omega Pistons
Arrow Rods
Decked block
Balanced Front pulley, crank, flywheel and clutch cover
Work carried out on head is:
Piper Cams blanks (can't remember what ones
Solid lifters with shims deep locating
Double springs steel retainers
Stem seal to suit double springach
Spring platform
Calisbro valve guides
Nimonic 80 exhaust valves
Stainless waisted stem inlet
Port bore inlet and exhaust ports
Fettle cylinder head blend ports open out throat area
Skim head
"Should" be safer at current power...
