RDS' Leon Cupra R
Oct 21, 2006
1,226
Norfolk
Those rear calipers look nice Rich. Would you be good enough to send me a PM with the prices of those calipers buddy? I'm looking into having mine reconditioned, so would be curious to see the price comparison.
Thanks. Have a good Chrimbo buddy :santa:
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
42DD shifter bushes turned up today:
So decided to crack on and get them fitted:
When removing the OEM bushes I noticed that the front/back bush was very soft, alot more worn then the side to side bush. This must be the reason I've been having problems selecting 3rd :think:. So fitted the bushes and took the car out, problem solved :D
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
hope you did too mate, they're really good for the price and so simple to fit. I didn't even have to widen the holes on mine, just give them a wiggle and on they went.
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Good work mate :D They're a cracking little addition to the transmission setup!
Found mine very precise to change gear. They do what they say and eliminate the slack within the throw of the changes.
The car gets better mate, keep it up! Hope you had a good Crimbo :)
ReDBull
Every day's a school day.
Nov 21, 2006
2,991
14
Lincoln
I think the reason I needed to enlarge the hole was the Forge short shift. I've read in a couple of place people with the quick shift had to adjust them to fit. Any word on your rod kit?
Oct 21, 2006
1,226
Norfolk
Were they the ones that were on back order from Awesome Richard? If they're back in stock, I'll order some. For loose change, they're too good to pass on. Hopefully it'll stop my third gear clunk, like yours has... I want to reduce my throw on my Forge short shifter to around 25% anyways ;)
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
Cheers mate, yes they're a great little mod for the money. Had a decent christmas, hope you did too :)
I've got the short shifter on mine mate, must just depend on the batch. No word on the rods, I've been keeping an eye on the group buy on facebook, Issam mentioned he would try and get everything posted the Friday before Christmas, whether he did or not, who nows. He's not back at work until 02/01.
They are mate, get them ordered, they won't disappoint.
RaviR50
2,756
Southampton
great looking car mate, i would've loved to get an LCR. Definately my next though.
Have you got a guide on makeing the debadged front grill?? i tried to have a look through, maybe missed it...
ARO
30
Carmarthen
non return valve
Great guide, thanks! Just wondered where i get a non return valve from, and what specs? I have searched ebay but couldnt see one suitable.
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
Hi mate,
Apologies for the late reply, just split up with the missus and trying to get stuff shifted back to the rents for the time being so the cars last priority at the minute.
I've not got a guide but I'm well overdue for fitting my oil cooler and getting all the front grills off for a fresh coat of paint so once that's done I'll get some pics for you.
Pleased to hear it helped mate:
BRAKE-SERVO-VACCUM-NON-RETURN-VALVE-GIRLING-LOCKHEED
ARO
30
Carmarthen
Hi mate,
Thanks for that, your car is looking mint!
ARO
30
Carmarthen
Oh just read the rest of the post sorry to hear about your difficult time, I have found having a car hobby deiffinetly helps, takes your mind off hard times for a while.
RDS
OEM+
Aug 11, 2010
2,276
11
Newcastle upon Tyne
Right, sorted myself out and I've got a couple of updates:
Fitted the oil cooler:
Currently running with the OEM slatted LCR grills as all the honeycomb grills will be getting coated in matt black plastidip.
And I've now got everything for the build:
I’ve also got the following on order from INA:
*144/20 rifle drilled Rods
* headgasket
* headbolts
* pan sealant
* oe connecting rod bearings
* 13x copper exhaust nuts
* 2x Mann oil filters
* 1x gates performance timing belt
* INA Manual Tensioner Kit
* Ferrea race exhaust valves x 8 OE Size
* OE Piston Rings 1.8t 20v
* Cylinder head rebuild kit
* OEM oil pump
* OEM water pump
* Relentless V3 manifold
* 2.0 TFSI coilpack adapters
Thats all for now :)
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Good udpate mate :)
Busy time ahead! Plenty of gear to get fitted there. When is the rest coming from INA? Any idea?
