What did you and your MK2 do today?
Nov 1, 2008
559
birmingham
Chevy Matiz 900cc ;)
Hahahahaha mate i would tell them to keep driving if one of them pulled up outside .
I remember when someone hit my dads e30 alpina bmw which at the time was newish and a quick car . They came to collect his car and dropped off a fiat ciquento in yellow LOL . My dad complained and the manager borrow him his car a rs 2000 which was more like it :)
Benjic2
1,030
I hate this f****** weather, I have shiney new parts staring at me waiting to be fitted and I can't even fit them because my other car is in my garage with no brakes so I can't even move it out :(
Bignod00
2,202
Lincoln/40,000 ft.
Isn't something that i did today but I've FINALLY managed to get hold of some of the footage from my Trackday at Blyton Park AGES ago!:funk:
Only a couple of minutes but its still made me remember how much fun it was.
Video is from a Go-Pro mounted on a Stg 2+ Audi A3 chasing me. He was slower on the straights but was stripped out running on R888's and massive brakes front and rear. Along with the 4WD it made it quite an even match up to be honest!:handbags:;)
Tiburon
120
Israel
Just received my short shifter .. fitting it in in the next hour.:D
its the eBay one?
how does it feel? not to much short?
Al
7,331
9
Well Jel :)
Nov 1, 2008
559
birmingham
Gloveboxes are used to prevent contact between potentially hazardous materials with the outside environment or operating personnel. Some of these materials or processes may be sensitive to ambient environment and hence need to be worked with under isolated conditions. This is achieved by containing such a substance within the glovebox equipment.
For more details visit us:
deekshainstruments.com
Whats this about mate ? I dnt get it !!
Mar 3, 2012
2,090
southampton, UK
Take of the airbox. One torx bolt i think t30 then just pull the airbox up as there are rubber clips that need to be pulled up(when you pull thevwhole airbox up) then you'll be able to see the old shifter you need to take off three small metal clips then take off both the black tops then there's a 13mm bolt that needs taking off once that's done then you need to pull straight up DO NO TWIST LEFT TO RIGHT. Just keep pulling it up and it will come off once that's done you need to allighn the new hort shift in place Beware there is a tooth missing on the cog of the short shifter that needs to go on the same bit of the gear box that you took the old shifter off from. Put everything back on and enjoy. The other bits you'll figure out :) enjoy
Sent from my LG-P920 using Tapatalk 2
