FroggyLCR
Yellow Beastie
Oct 2, 2012
251
Norwich
Fixed rear washer fluid leak and fitted my Badger 5 TIP :) Still needs a wash though once I have located and fixed a coolent leak at radiator.
517
Penzance Cornwall
Aug 27, 2012
581
Maidstone, Kent
My new handle and mech I got today
Note for LEE69, I checked it against the part number on that parts website and comes back that the colour is Persia black lol
csd_19
2,279
28
Angus / Edinburgh
Check my original post, it says testdrive vid right under the pictures. No error codes whatsoever (yet) :) Made a testdrive and drove it hard, very happy with it.
You'll eventually get a code for an N249 fault, purely because the ECU can't open the HKS like it can with the normal DVs to regulate boost etc ;)
I still swap about between my Hyperboost DV and my REAL :p HKS SSQV from time to time :D
nally270lb.TQE
439
gloucester
Took it to Badger 5 to have smoking exhaust lpoked at, seems as though my pcv non return valve was broken in half and was leaking. Bill fixed that and had a look around and did some logs. All fine now and was happy with the dyno run results . Felt a lot smoother and quicker on the drive home. :)
