Another Small Update -
Spend another couple of hours messing around in the garage again.
I decided to finish off the dashboard so i hastily fitted the panel below the steering wheel only to discover i forgot about the wires for the headlight switch - managed to fish them through the hole with a bit of TIG welding wire and then get them connected
I even refitted the throttle pedal and wired it back in, i forgot it was a total bitch to get out due to a big lump of white plastic being in the way..... it was as much fun refitting it as it was removing it.
I then stuck the passenger airbag back in and loosely fitted the Glovebox - i've still got to adjust the latch as the lid needs a bit of a slam.
I also decided to run the Power cable in for the battery relocation.
I was gonna take it through the bulkhead behind the glovebox but i looked at it and as i had the front wings just sat on loose i whipped them off and ran the cable up the front frame rail and out under the wing then back in....
Handy hole in the frame rail -
(i will be putting a grommet where the cable passes through)
Comes out here as the frame rail is blocked further up -
(i need to drill a hole in the OEM Grommets and seal up with silicone)
Comes into the cabin here -
So hopefully next time i get in the garage i will start doing bodywork.
I've also been looking at either buying a carport or making one or buying a tenty one or something, think it would make the rebuild / painting a lot easier.
Thanks for reading.
