Definately +1 to James post.
I think I speak for most of the forum when I say I wish I was closer to lend a hand lol
Thanks Barney
Are you going to buy some heat lamps or heaters for after it's sprayed? I hope the police aren't watching what you're taking into the garage they be thinking you're growing you're own lol.
never been partial to any "home grown" herb or veg.....
Small update -
It's been a while since i updated, sorry to all been doing boring stuff lately prepping the garage further for the impending paint job.
I finally got round to painting the last wall white - not bad, it only took me about 6 years to finish that job
I've managed to have a re-arrange in the shed and clear the shelves that were down the sides of the garage.... once they were clear i took them down to give me a bit more room for painting.
I managed to get an extractor fan from e-gay - it's a bit of cheap Chinese sh*te but as long as it lasts the duration of the paint job then i'll be laughing. The auto opening and closing of the shutters didn't work so i removed the motor and installed a bit of trusty welding wire to manually pull the flaps open and shut.
I was planning on mounting it in the window but it seemed like a better idea to just take out one of the panes from the door, i couldn't decide if the fan would have been better in the top or bottom so i put it in the middle
Mounted the fan up and quickly wired it in (still got to run a permanent supply to the fan)
Took me shelves down -
The garage is looking nice and bright now (crappy phone pic makes it look a bit dull)
The garage is finished now just needs dedusting and cleaning out after all the sanding work is done.
I did some thinking about the warmth in the garage.... - i already had a small electric convection heater which took the chill off nicely but wasn't much good for getting the garage warm (which i'm gonna want to do to get the paint to fully harden / dry quicker)
So I had a trip to machine mart today and came back with a 3kw Infrared Heater -
Got too say it's excellent - actually a bit too hot on full tilt, i've been turning one of the elements off and just running on 1.
Warms the panels off nicely which drys the primer i've sprayed in about 5mins. I only turned it on once all the paint fumes had been extracted out thanks to the fan
I decided to start tackling some more of the rust around the rear lights / where the rear bumper meets the body and along just behind the rear wheel arch, it wasn't too bad just starting to bubble nicely.
The rust seems to be where the bumper has been rubbed the paint away.
Quite hard to show in the photo but this is after i cleaned it up -
I gave it a lick with some Upol Zinc 182 primer to protect it until i have a chance to put the main primer coat on.
Next up was to remove all the old sealant from around the front windscreen - i had scratched the paint to hell when i butchered the smashed screen out.
I removed all the old sealant and took it down to bare metal to be sure -
Gave it a lick of zinc primer -
So thats it for now. Tomorrows plan is to put some filler on the roof where i welded up the nasty handsfree aerial hole and do some minor filling / sanding prior to shooting the real primer.
Ohh and i've got to say big thanks to PhillC, i've now got all the Glass sorted including the Windscreen and Tailgate, also got loads of bits and pieces from him so happy days.
Thanks,
Graham.
