Just had mine repaired by PDT in Sunderland (thanks Hargo). After living with no fuel gauge & wonky temp gauge for ages, when the imobiliser started to play up it was time for action. If like me you dont fancy doing it your self then PDT are a nice bunch of chaps and very reasonable. The guy had a theory as why this happens - wiring loom not designed for use with ajustable steering so its too short and puts undue strain on the connector block when the wheel is pulled toward the driver. He said he has got vehicles to start by moving the ajustable column in and out which I suppose is like wiggling the connector block.
