Just had mine repaired by PDT in Sunderland (thanks Hargo). After living with no fuel gauge & wonky temp gauge for ages, when the imobiliser started to play up it was time for action. If like me you dont fancy doing it your self then PDT are a nice bunch of chaps and very reasonable. The guy had a theory as why this happens - wiring loom not designed for use with ajustable steering so its too short and puts undue strain on the connector block when the wheel is pulled toward the driver. He said he has got vehicles to start by moving the ajustable column in and out which I suppose is like wiggling the connector block.
If i buy a cluster from a breakers yard will i just be able to fit it straight in (Plug & play)?
Nicky
Apologies for my ignorance but is this much of a job?
Nicky
x
wouldnt go near the bonnet , the earth your looking for are the ones on top of the gearbox tunnel and at the base of the 'a' posts
Hi
Forgive me but I'm very new to the ibiza..
I've bought a 2003 tdi sport and I've noticed that the temp gauge has worked when it feels like and now the needle sits at the 70 mark with the ignition off and won't retract back to the 50 mark.
With your collective knowledge would this sound like an issue with the temp sender or the clocks.
Thanks in advance.
I finally got around to doing this last night, took a while to get the cluster unit out, and I snapped the purple retaining clip holding the green connector in after using too much force.
Took my time to solder, majority of them went OK, not too much solder, bar one, tried to tidy it up, then accidentally connected two, then a group of four (pins for the warning lamps 2,3,18,19), so I spent 20 minutes just sorting out the mess, once it was tidied up and I made sure there was no shorting, I put it all back in the car.
It all worked (and car started) thought I might have destroyed something, however although the trip odometer displays i.e. since resetting it, the actual odometer shows nothing (not zero) but there is no display.
I have put the cluster back in so I can use the car, but I am wondering what has happened to the display, the bottom portion displays, so why doesnt the actual car mileage show any more?
Any help would be greatly appreciated.
PS. I could definitely not be a surgeon, couldn't believe how shaky I was looking at the tip.
When re-seating the plastic surround, I've had it where the locating pins are quite tight and it's not quite flush with the PCB. Sounds like you'll need to strip them down again, clean the black contacts on the PCB side and the edge of the carbon connector strips beneath the LCD and make sure all is seated nice and flush. I normally use isopropyl to clean contacts/connectors, hope that helps.
