second wheel done - taking 4/5 hours per wheel - not going to lacquer these come off for winter so just going for the polished face
Well, started off in a good mood so decided to change my dogbone mount bush for a powerflex bush :), got under car and sprayed all bolts then went for a cuppa............came back and sheared one of the mount bolts :cry::cry::censored:
Tried to pull out the mount but it was stuck on the sheared bolt :censored:
Bolted it back up and had a wee tantrum.......................so fitted a new front splitter
Still pi**ed off about the bolt tho..........
went outside to it at 5.40am to give it a jumpstart so the mrs could get to work. didnt work so i ended up driving her in my van then coming home, fixing the car and watching tv for two hours before i went to work
Everything done esterday, mounted bry new tyres on the front, and fixed AIRBAG light problem, find a broken airbag wire in the driver seat which touch to the ground, and come error: short circuit to ground, now all sorted :)
Sent from my LT26i using Tapatalk 2
Thanks...Prosport from the US...bought them over a year ago, just got round to fitting (wasn't easy). Can't remember how much but weren't pricey in comparison to others :D
