i tried to tidy mine further today, not sure itll work long term but on a quick test run it worked fine. excuse the messy bay that will be sorted soon enough! Also apologise for my lack of mechanical knowledge lol im a pipefitter not a mechanic!!
i originally had a hose running from the right hand nipple on one of the valves (can't remember if it was right or left, can someone help with what one it was incase i need to return it to its previous state??) to a round silver thing under the boost pipe (is it the n75??) then from there to the black/white regulator (if thats what it is haha)
i removed this and ran a hose straight from the silver thing to the black and white thing
i then ran a hose from the black/white thing to this y piece, one branch to inlet mani and one to DV
here is the T at my DV (other hose running to boost gauge)
and finally a shot of the hose running from black/white to the silver thing (just out of view) this is how its currently set up and running ok, but it means that the 2 originally n249 related things are completely disconnected to any vac lines and are only plugged in electronically. My question is, will this cause any problems long term???
When i set it up earlier i just assumed it would be the same as resitoring the valves but leaving the valves in place and plugged in electronically. Sorry if this makes no sense!!
