Found this
hey guys i keep getting asked about*this so i though i would post an
how to, as with all how too's be carful, if you done think you can do it dont, i take no resposibility if you **** up lol
this mod takes out the n249 valve, this valve is under constant vacuum and at any time can open the dv, it can cure surging and rough throttle
Right ho
this is the* most simple route, basically were just capping off the hard line that the DV connects to, and running a new vacuum line from the DV to the vacuum on the FPR and just insert a T-fitting on that line. You can clip or zip tie all ends of the vacuum lines and were done.*
1) Cut factory clamp off FPR rubber line
2) Plug a "T" into the line you pulled off FPR and put a new piece of hose from the T back into the FPR
3) Now your FPR is plugged in and you still have 1 portion of the "T" not used.
4) Use that no used leg of the "T" fitting for your DV
Pics
Remove the engine cover
To reveal this
Theses are the bits were interested in
1 = the dump valve
2 = the fuel pressure regulator
3 = the n249 valve
The arrows
Blue is the hose going from the dv to the n249
Yellow is n249 going to the dv
Green is the n249
Red is the hose off the fuel pressure regulator
How to:
Remove the line going to the top of the dv, numbered 1; cap this with a bolt,
next you can either cut and tee into the fpr line (the tube that comes out of the fpr, the fpr is the silver canister looking thing above your intake manifold, this is numbered 2. the line is a black braided hose. personally I cut the hose clamp off and installed about 3" of new tubing from the fpr, so I didn’t have to cut the stock tubing (just in case I want to make things look stock). from the fpr whether you cut the existing line or installed a new one, install your 't' fitting. Now you have a line from the fpr, to a tee going back into the fpr line and a spare, this spare goes to the top of the dv, numbered 1 and that’s it your done
Make sure you ty-rap all connections. You’re done. without a boost gauge, this install requires a 3-way t. if you want your boost gauge hooked up as well, you can get a 4-way t... however I haven’t seen any 4-way tee's with 3x3/16" ports and 1x1/4" port... so you'll need to get the 1/4" changeover and a small piece of tubing to make the 4-way work.
