Running a relentless mani/dp/sports cat with a milltek non res. fmic known as the 'welly' cooler. Same as Sam bryants.
Hmm, I've seen too small an intercooler and/or downpipe suggested as reasons for the flutter sound/surging issue but I guess that's probably not the case for you.
She cleaned up lovely, looks fantastic in the pictures.
I'm finding the fluttering happens on my car in 3rd gear and above. Its beginning to annoy me now. Need to start eliminating all the possible cause, i suspect its the dump valve to be honest. I'll be interested to hear how you get on with. finding the cause of the fluttering, keep the updates coming.
Cheers mate
It's a lovely shade of red certainly and looks nice when it's recently cleaned.
I did some testing this evening with an HKS SSQV dump valve. It's utterly hilarious, got a real Fast and Furious, highly-tuned JDM car type noise, kept blipping the throttle and getting all sorts of noises.
Oh yeah, that's right, almost forgot I was supposed to be testing to see if the car still made a flutter sound on boost. It didn't. The HKS valve cannot be "pushed open" by boost like single-piston valves like Forge 007 and 008 can. So I guess it's a real possibility that the DVs are causing the issues.
I'm going to pop another shim in my 008 for a total of two plus a yellow spring and see if that helps. If not then I'll try a blue spring.
Oh, another thing, checked my B5 TIP and the bloody thing is still slipping off the adaptor
I've pretty much had it with that thing now, I'm going to order the SFS one and sell the B5 one on a local car forum. I know the B5 works well for a lot of people but I tried everything I could and still couldn't get it fitted right, I think I'm just unlucky in that the coolant pipes run too close to the turbo to get a good fit.
