Meh that time of year again sadly
Driving to work...started to speed up building up the revs and suddenly (Chokes...) loss of power, still driving but yea...
Got to work and turned the car off, trying to start it back up again (it will kick into life but not on the first tick). Car is idling fine no cough no signs of misfire.
As soon as I got home error codes...
3 Faults Found:
008598 - Oxygen (Lambda) Sensor B1 S1: Signal too High (Rich)
P2196 -- 004 -- No Signal/Communication - Intermittent
008852 - Fuel Pressure Regulator Valve (N276): Open Circuit
P2294 -- 002 -- Lower Limit Exceeded - MIL ON
008580 - Engine Coolant Temp Sensor on Radiator Outlet (G83): Signal too Low
P2184 -- 001 -- Upper Limit Exceeded
Saved the error codes then I wiped the codes...Took it out again for a evening drive.
1 Fault Found:
008851 - Fuel Pressure Regulator Valve (N276): Mechanical Malfunction
P2293 -- 002 -- Lower Limit Exceeded - MIL ON
Erased the fault again, and no faults appear However, no power...bit coming from low but nothing from med range (lucky to get up to 60 )
Please correct me if I am wrong but does this mean my High pressure fuel pump as died?
3 Faults Found:
1 Fault Found:
