D.K
LCR 225
Oct 24, 2007
6,408
se london
I took the car along with Mylo off to AmD Essex today for a bit of Christmas fun :D
The aim was to finally put the stage 2 AmD map on the car, I've had all the suporting hardwear mods for awhile now so thought it was time for a new map.
Before any mapping was done the car had a run on the rollers to check what power it was producing, it made a heathy 290BHP (Not sure what the torque was)
It was then scaned for any fault codes, this all came back clear.
Then it was time for the stage 2 map :D
The results were a bit mixed we got 295BHP but only 240LB/Ft, it had lost 66LB/FT over my previous best run.
We tried another file but the car would'nt produce any more torque :think:
The last time the map was tweaked was after it came back from Milltek after doing the development work for the new Turbo back exhaust system, At the time Kenny made 2 new map's, 1 with a bit more boost than what I had a stage 1 and another with even more boost, Kenny had kept both these maps so we decided to give the one with the higher boost a go, This map should instant results and made 290.9BHP & 325LB/FT :D thats more like it :D They are looking into the stage2 map to see where all the torque went so the full stage 2 might still go on but in the mean time I'm running another "custom" map :D
On the road the car feel's even more savage than before, when I left AmD the roads were very wet and it was dark so I did'nt give it too much but :whistle: but the boost certainly comes in a lot stronger, I even had what felt like wheel spin in 6th gear at 60MPH :-o
Big thanks to everyone at AmD Essex :thumbup:
D.K
LCR 225
Oct 24, 2007
6,408
se london
Picture time
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Don't forget mate the engine was probably running hot by the time they managed to get the final map on. Stick it on the rollers at the next rolling road day and I'm sure you will see a bit more. Regardless of numbers that boost curve is bang on, one of the reasons I love my map done by the guys as its all usable with no stupid spikes
RS6
Nov 24, 2009
1,110
Thats pretty sweet DK bet your pleased with that! strange how the maps needed to be changed there :D
I need to get mine back down to AMD mine was running the forge tip with my result of 319.4lb/ft torque and AMD's stage 2 map + airbox
now running revo stage 2 and badger 5 tip with jetex cone so be interesting to see what happens with the setup now!
glad your happy! :D makes it more fun to drive deffo!
D.K
LCR 225
Oct 24, 2007
6,408
se london
It's only running a little bit more torque than it was before but it now holds it longer :D
There will be a RR day at AmD sometime around Feb or March so keep your eye's open
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Nice dipstick squire ;)
Text you about the results at AmD, but well done again mate. A1 service from them as usual I see :)
D.K
LCR 225
Oct 24, 2007
6,408
se london
Cheers Tom :D
The car was flying today, nail the throttle and it will put you in the back of the seat like you'd expect, even on half throttle it is devastatingly quick :D hold it at 15ish PSI and it fly's with no effort :D
The exhaust and DV noise has increased aswell :D
D.K
LCR 225
Oct 24, 2007
6,408
se london
I treated myself to some new detailing bit's over Christams,
3 weeks worth of dirt :whistle:
Snow foam lance from CleanYourCar.com
http://www.cleanyourcar.co.uk/washing-and-drying/snow-foam-lance-various-fittings/prod_371.html
Valet Pro - PH Neutral Snow Foam
http://www.cleanyourcar.co.uk/washi...ro-ph-neutral-snow-foam-1-litre/prod_516.html
I've not had a chance to try the other stuff out yet due to the poxy weather, hopefully I'll get to have another go tomorrow
Gtechniq - Glass Sealant Kit
http://http://www.cleanyourcar.co.uk/engine-and-exterior/gtechniq-glass-sealant-kit/prod_911.html
Valet Pro Dionysus Trim Glitz
http://www.elitecarcare.co.uk/valet-pro-dionysus-trim-glitz-500ml.php?manufacturers_id=52
Auto Finesse Citrus Power
http://www.polishedbliss.co.uk/acatalog/auto-finesse-citrus-power.html
Oct 21, 2006
1,226
Norfolk
The Snow Foam Lance is such a good piece of kit isn't it! I personally use Super Snow Foam with my lance, that gives a very effective covering, without stripping wax etc. I haven't seen the PH neutral product before, so I think I might give this ago next, as it seems to have very good write ups when referring to its strength in cutting through grime effectively; it looks like it got right to it in your pictures?
The car is looking tops as always Darren. Happy New Year!
James.
EL
Forever Alive
Mar 17, 2008
2,931
Bickley, Bromley
Nice purchases there Darren although you can't really call that dirt. I will bring my dirt bag down and then you can test this stuff ;)
Happy new year mate!
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Mmmm a wet LCR :D
So you happy with the purchases then mate? Thinking of getting the lance sorted out next year and foaming up my LCR ;)
