Diesel Fr mk2 hesitant help
/dev/null
1,649
101
I'm having all the injectors replaced the week after next (covered by SEAT UK) but I don't think it is that. When it does it, try unplugging the MAF sensor for a few moments and see if that cures it - it did with mine (see above).
Scby555
166
I'm sure the dealers report said my injectors were ok so don't think it's that - when one of mine failed recently the car just cut out dead.
/dev/null - you;ve had this issue over a year now ?
you said disconnecting the maf fixes this issue - yet fitting a new MAF didn't?? I'm confused, this issue is well dodgy.
I'm going to try a few things, then it'll go into the local garage and I'll just get them to start changing stuff
Scby555
166
That might be a nice workaround I'll call it, but it doesn't actually explain what has broken. My std car was fine two weeks ago and now it isn;t so the EGR or something else must need replacing?
Scby555
166
your £2 fix is merely masking the issue.
I know it's only £2 and it seems to work but this is my company car so I don't care if it costs £500 to fix it - I ain't paying, work will be.
And even if it was my car, I'd still like to know what is actually broken.
AndrewJB
Aug 16, 2007
11,209
485
Maranello
My EGR is removed now so im not masking anything, It was a cheap fix and served its purpose until i got round to completely removing the EGR
If SEAT or your company are willing to fully investigate then get them to do it
Dec 31, 2007
1,479
Reading
Do you not realise that if your company is better off, you will be better off? It always amazes me how short sighted some people seem to be about work expenses. The company won't be paying bonuses and pay rises if they are making losses, and they will likely pay better pay rises and bonuses if they are making more profit.
Scby555
166
SEAT are useless. If there is no ecu error codes to tell them what to replace they haven't got a clue what to do.
Before I send my car to a real mechanic to look at I just thought I'd look here for the proper answer but seems like no one knows what the issue is. Some people on here have just put up with this issue for over a year which is just silly.
The way the car is running now it feels about 50BHP down :(
redwhalley
my car has been a bag of sh*t for three weeks was told to change the maf but that was not the problem and as normal seat said i would need a new turbo . so took to a friend at vw he took one look under the bonnet and his reply was your manifold is blowing the hole engine bay is covered in black dust, funny when they changed the maf sensor the seat guy did not see all the dust in the engine bay. i had all the both problem no power the car was fine in 1,2,3 and then lost all get up and goin 4 ,5 ,6 . plug the hole on manifold just to check this was the problem and the car was good as new , new manifold next week.
Scby555
166
To a point yeah.
But I want it fixed properly instead of cutting corners. Fixing this is stil cheaper than them buying me a new car.
Scby555
166
"plug the hole on manifold" - any pics of where the hole was or was it really that obvious?
Not sure this is my issue. I'm sure I would notice excess black dust in the engine bay (runs outside to check) :)
redwhalley
No pics as I am not running car at mo . But if you want to check its the same problem just take cover of engine so you can see manifold turn car on and before the car heat up you can feel and smell the gases coming out. Also just run ur hand over the top of the engine should be quite clean is ur hand is black u may have the same problem.
/dev/null
1,649
101
Hi,
Yes, unplugging the MAF solved the problem but replacing didn't - I posted a thread about that specifically on here. I have the EGR gasket mod - made no difference at all.
When mine does it, you can see the engine literally shaking in the bonnet - almost jumping about!! The car sounds rough as hell, like it's coughing, the exhaust fumes are very hot if you put your hand near it (far more so than normal). This is what leads me to think it's a stage 1 regen but it seems to be far worse than anyone else reports (most people say they don't even notice it).
So far I have tried replacing:
Fuel filter
EGR Gasket
MAF
None help.
/dev/null
1,649
101
I would suggest binning your dpf as it is a consumable that or get a new one
Wish I could lol, but unfortunately I don't have a spare either 700 or 1400 quid (depending on whether it's binned or replaced). Having said that, it has done 110k and they reckon they need changing at around 100k. I've had the problem since about 60k though.
ChesterRover
Hi,
Fuel filter
EGR Gasket
MAF
None help.
I have the exact same issue on my 2006 2.0 TDI FR, the engine shakes like crazy and sounds like a bag of spanners, runs extremely hot and very strong fumes.
Going to price up DPF removal tonight as a final attempt to cure and if not its time to get rid.
