Bit of an update, after picking up a brand new turbosmart boost gauge for £25 delivered I thought I better crack on and get a few jobs done on the car!
After wanting to locate this in the main right air vent I thought better of it as I read a lot of poor fitment
reviews. I decided on a turborevs universal gauge pod, it fits perfectly in the top air vent so was a good compromise!
After running the hose through the usual drivers side plastic gromit It was just a case of wiring it into the glovebox using a neat little fuse adapter pictured below
The result once fitted
I also did the n249 bypass an the car definatly feels a lot more responsive now which is good plus I haven't had any warning lights that I'd read about previously!
I also fancied a spot of inlet manifold polishing, after working my way from 40 grit though to wet sanding 1200 grit I was pleased with the result. However then I decided to give it a quick whizz over with my da polisher and a dead compounding pad *loaded with autosol.... I'll let the pics do the talking!
I'm majorly pleased with how it's came out, the finish is amazing with the polisher on it!*
Now for the charge pipe !
