Quote:
Originally Posted by STdemoniac
today upgrade dogbone mount and make video, movement before and after
http://www.youtube.com/watch?v=sgaen1Ny6dI
Good work with the video!
and today i change a new termostat .... :funk:
Finally done my door seals with the right stuff but I can't for the life of me get the last 2 bolts back into the bottom of the panel on the driver side door. I think I've damaged the threads as its ripped one of the bolts. Pretty gutted as I now have to take it to a garage to have a look at it.
It's deffo the threads that's damaged. I took the butyl stuff off so that the panel was flush and it still didn't catch. Really pissed about it as its the 2nd time I've done this and its never caused any bother.
You might have got away with it the other bolts and the butyl might be enough, if not they will need re-tapping.
i went saturday to a tuningshow and bought xenon there, so i installed it today.
fitted my silicone tip, happy with results but i was very nearly defeated when trying to fit it!!
FINALLY got the door seals done lol. Just in time for the bad weather.
I also raised the beam on the HIDs today soooooooo much better.
Got the LED rear numberplate bulbs in as well, there bloody bright lol.
Installed Bailey blow off dump valve , including piper cross induction kit :D
Just wanting the exhaust system now :) :D
Just a quick question but can anyone tell me the difference between the 1.9 tdi sportrider to the cupra inside the engine?.. i know that the ecu and turbo are different sizes and injectors but what else ?... if i replced my turbo , injectors and remap ???..... would this match cupra standard?
cheers much appreciated
Was that dog bone knackered in the first place? Also did u get vibrations on idle after fitting polly ones?
the old one dogbone still in good condition, main reason why i change it, course exhaust sometimes on cold engine have noise, looks like touching chassis, i be at AMD but he can`t find anything, so that why i buy dogbone and replace it, and noise gone :) another good point now , i feel less play when change the gear :)
about vibrations can say may a bit more feel vibration on stering wheel on idle , but nothing horrible :happy:
