tobrien1
Got part way through fixing my slow-speed fan issue! It's a lot more fiddly than I thought it would be lol.
Seatmann
Rough around the edges
Sep 16, 2010
5,575
10
Scotlanda
Took the fuse out for the radio AGAIN as it's having a hairy fit at the mo, need to figure it out and sort it or get rid though.
G1NG3R
Had 4 new coilpacks fitted yesterday and booked in next week for 2.5 " cat back no middle box.! £80 sweet. ;)
Seatmann
Sep 16, 2010
5,575
10
Scotlanda
New strut top bush but don't hold out much hope for killing the knock, gave it a dam good wash and also adjusted the camber slightly but I think I need to loosen the sub frame bolts and give it a dunt accross to the right a bit. I'll check in daylight on flat ground but it looks a bit like the left wheel is sitting out further than the right.
Goo
156
Gave it a wash polish wax and noticed i have way to many stone chips on the front that i want to get sorted. brake pad light also came on so will need to get some new ones :(
anyone know how far you can go once the light comes on?
Deleted member 12147
I finished painting my custom LCR grille and removed my milltek resonated pipe and replaced with non res.
Miller 20vt
No longer a newbie
Sep 13, 2011
312
Hampshire
www.pijin.co.uk
my 20vt had the recall on all 4 coil packs along with some new ngk plugs friday and then today she had a cambelt kit, water pump, aux belt, fixed the secondary air pump, oil and filter, pollen filter and done the water leak mod. after all that i cleaned her inside and out and polished her.......me and my bro have been very busy today but so worth it she runs like a dream!!
