hybrid boost logs
Jul 4, 2007
1,674
bristol
this is with minus 4.5 on uni setting.
Code:
		RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization		RPM	Voltage	Temperature	Temperature
	TIME					TIME					TIME
Marker	STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF	STAMP	 /min	 V	°C	°C
	9.9	1960	114.3	11.07	43.72	10.4	0	0	0	0	10.8	2200	13.65	97	29
	11.2	2360	165.4	15.99	80.89	11.71	0	3	0	0	12.21	2800	13.65	98	28
	12.61	3000	191.7	20.5	131.31	13	0	3	0	0	13.4	3520	13.02	98	27
	13.92	3800	191.7	22.55	169.53	14.41	3	2.3	3	3	14.89	4360	13.65	98	26
	15.31	4600	191.7	22.96	186.89	15.71	3	2.3	3	3	16.2	5000	13.44	98	27
	16.72	5160	191.7	22.14	195.97	17.12	2.3	1.5	3	2.3	17.52	5440	13.51	97	27
	17.92	5600	189.5	21.32	202.44	18.3	2.3	1.5	2.3	2.3	18.7	5840	13.51	97	29
	19.1	5960	186.5	22.14	212.47	19.5	2.3	1.5	2.3	2.3	19.9	6200	13.58	97	29
Jul 4, 2007
1,674
bristol
that gives me a little more piece of mind was pulling 9 before. it holds 20psi now at 6k but spikes lower. wiered
still confused why i wont take any advanced timing though cam to cam who knows
2,170
Cambs
Looks alot better now Joe, want to try and keep them under 5's which they all are.
Inlet temps look good too, glad the cooler is doing its job :D
csd_19
2,279
28
Angus / Edinburgh
Sorry fella, missed the updated logs on here :rolleyes:
293 torques and 266 bhp this time round? :)
Jul 4, 2007
1,674
bristol
Hey thanks mate! I'll save this one and see how the dyno compares. Cars running real smooth now the timings turned Down really does fly I love it. Just
A shame I can't afford to run it everyday :)
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
not what I asked...
logs from block 003 shows actual ign advance if you have them. no matter if not, next time log 003 as well maybe
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
without knowing what physical timing its actually running, any comments made as to why its pulling timing are irrelevant as its running the max it wants to run as the CF's show. pulling timing which may be running higher than a lot of others, now its running a larger fmic, is a change. So long as CF's are under control, which is the important thing alls good.. But I would like to see its timing on block 003 to compare to when it was here on its smaller fmic
Nov 2, 2004
9,335
South Wales
If 020 is repeatable then log 003 on its own.
I tend to do a couple of runs with two blocks then focus in on one to get better sample rate of that block.
Jul 4, 2007
1,674
bristol
group 003 for you bill
Code:
	Group A:	'003				Group B:	 Not Running				Group C:	 Not Running
		RPM	Mass Flow	Load	Ign. Timing
	TIME					TIME					TIME
Marker	STAMP	 /min	 g/s	%	 °BTDC	STAMP					STAMP
	250.13	1640	36.64	100	0.8
	250.53	1760	39.94	100	0.8
	250.93	1840	42.53	100	0.8
	251.33	1960	48.58	100	2.3
	251.73	2080	61.61	100	2.3
	252.23	2240	74.22	100	2.3
	252.73	2440	89.61	100	1.5
	253.13	2640	101.11	100	0.8
	253.53	2840	118.86	100	1.5
	253.93	3120	146.31	100	3.8
	254.33	3360	139.94	100	4.5
	254.74	3640	162.44	100	3
	255.13	3880	175.94	100	3
	255.53	4080	175.28	100	3
	255.94	4320	180.69	100	3
	256.34	4520	178.64	100	3.8
	256.74	4680	185.78	100	3.8
	257.14	4880	186.25	100	3.8
	257.54	5040	193.69	100	3.8
	257.94	5200	195.97	99.2	4.5
	258.44	5360	200.86	100	4.5
	258.84	5520	200.06	100	3.8
	259.24	5680	205.86	100	3
	259.64	5760	210.33	100	3.8
	260.04	5880	215.31	100	3.8
	260.44	6000	216.39	100	4.5
	260.84	6120	218.56	100	3.8
	261.33	6280	217.08	100	3.8
csd_19
2,279
28
Angus / Edinburgh
And a wee graph for you Joe - did the TC cut in during that log? There's a dip in the maf readings around the 3300-3600rpm mark, you can see it on the graph.
Jul 4, 2007
1,674
bristol
That's just a bit of wheel spin as it hit boost lol
Cheers for that mate hope my timing looks ok. I'm really interested to see if the graphs are accurate seems like it's got too much torque!
