My Black Magic Mk1 LEON Cupra TDI index in 1st post
Feb 22, 2009
3,618
South Wales
Just bought Halfords DOT5.1 High Performance Brake & Clutch Fluid
622019
The Halfords DOT5.1 High Performance Brake & Clutch Fluid has a non silicone base and is recommended for vehicles with ABS. It meets and exceeds Super DOT4 specification.
features & benefits of Halfords DOT5.1 High Performance Brake & Clutch Fluid
■ High performance brake fluid which is ideal for cars & vans
■ Meets & exceeds Super DOT 4 specification
■ Also suitable for vehicles where ABS is fitted
■1 litre easy pour bottle
Note: Halfords DOT 5.1 is not suitable for vehicles with mineral braking systems requiring LHM Plus: eg. certain Citroen models. If in doubt consult vehicle handbook..
Retail £12.49 for a Litre with trade card £5.34 :)
and
Hopefully tomorrow my Clutch will be sorted :)
Nam-uk
1,162
338
lancashire.
that Gunson Eezibleed setup looks very good, post back your thoughts on this, will have a look at a few reveiw vids i have seen on this as well.
just had the front discs done and pads the brake system was bleed at the front and Paige Brake fluid was used but one of them vacuum bleeders were also used and it did not just take the line fluid out , rears will be done when needed.
Feb 22, 2009
3,618
South Wales
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
aint that for a 1.8t powered car? with half your torque?
just buy a stock sachs dmf and uprated sachs disc and cover. unless your not keeping the car.
Feb 22, 2009
3,618
South Wales
As a result of
170 bhp @ wheels
199 bhp @ flywheel
286 lbft torque
Clutch gave up last week so today we removed the Gearbox (Loads of fun) to find the friction plate was in good condition!
Just seperated from the middle- Oops (is this what they mean by a 2 piece clutch lol
after removing the clutch we found the DMF has twisted and Jammed
here you can see the Bolts are no longer in line with the holes
good side as gap should be
Bad side in flush with the starter ring
In the morning out come the Grinder!!!!
3,618
South Wales
well today went better than yesterday
cut away middle of DMF
installed new DMF
installed new clutch :D
and took gear box out of this and fitted back into car
john_tdi
mmm 385lbft
Feb 21, 2007
687
s wales
went through 3 of them. the second one was even sent off to be rebuilt with stronger pins etc, but only lasted 14 months. the 3rd box I got second hand then sold the car on as I'd had enough. Using 3 different dyno's my lowest torque reading was 365lbft and highest was 385lbft. Which is at the top end of what my setup can produce. I've been told the 6 speed aint that strong.
