I agree, is your engine playing aswell yea_good_1? Im starting to think its just a matter of time before mine does, especially since iv just had Revo done.
vRSy, whats the difference between the 2.0 TFSI and the 2.0 TSI?
has anyone actually done more than 20k miles in there cupra/boc?
2.0TFSI came in 2 forms. 200ps had k03 and 230ps had k04 turbos. fuel pump was the same on both but the k04 TFSI had better injectors. this is the older of the mk5 GTI/cupra VAG engines. The 2.0TSI has only one variant of turbo and has a much higher rated fuel pump as standard. the tfsi had a major weak point/restriction with the high pressure fuel pump when mapped. This is what is found in the facelift octy vRS and mk6 golf GTI
The new TSI does not suffer any fuel issues at all and can manage 20bar more pressure.
If the injectors from the 2.0TSI fit the 1.4TSI then we might be in for the win.
FWIW it might be a straight fit. for example the RS4 injectors were a direct fit for the 2.0TFSI. Only issue was the spray pattern wasnt optimal, could be a similar scenario with the 1.4TSI
im at 11k miles and not had any problems as of yet.... but i havent had the revo map. only got the bov on there, and thats easy enough too take off if any problems do occur.
hopefully, will run latest version of REVO suitable for these modifications. plan is to check on TSRs rolling road to be sure.Are you keeping the Stage 1 revo or going another route once its up and working again?
Was wandering if you considered an engine swap at all,
1.8T and 2.0TFSi engines are available for less than a grand. If they could be made to fit it would be awesome, bombproof engines.
Would need custom engine mounts nd exhaust, not sure if the gear boxes would match up though,
I think if mmine bblew i would be tempted to go this route for piece of mind. Also 280hp in a car weighing 1150kg would be insane
Me and my mate wer looking At an audi a1 with a 2.5tfsi engine in and they said it fitted on the same mounts as the 1.4tfsi that came out of it!![]()
thought of this months ago, GTi engine with 6 speed DGS would solve all problems, but the quote I got to fit and wire in was 10K!!!!!!!!!!!!!!! slight lack of 10K meant a rethink on that one.Was wandering if you considered an engine swap at all,
