Danny any chance you could PM me some pics, advise and maybe required parts for the 4wd conversion
I bought a BT recently which was from a mk4 golf 4 motion running a 1.8t so downpipe is already modified to clear front transfer box
Had a look through your thread but were you able to keep the interior too?
Sorry for the hijack graham
Thats ok mate just don't make a habit of it
You got a build thread Danny ? And did you bother bracing the shell when you removed the back end (did you support the shell on axle stands etc) ???
Ronin, all the leon 4 panels can be bought from seat, but they cost nearly 2 grand (thats for all the little brackets etc for the conversion). Thats why i decided to go with the S3 shell for £200, phoned a couple of breakers and 2-300 quid seemed to be the going rate.
I used VAGCat to identify panels which are different between the 2wd leon and 4wd and compiled a list of part numbers from there. Still have it if you want ?
I know its hard to imagine from the pics whats involved but when i start removing the panels from the leon i think it will be a lot clearer whats involved.
I don't think its for the faint hearted or people that hav'nt done welding etc before.
The main differences between the shells are -
The boot floor is higher on the 4wd for clearance for the diff etc, also the spare wheel well is in a different place.
The chassis frame rails (the boxy type section that runs beneath the car for rigidity) are different in respect to the height and angle, where the rear beam / trailing arms mount, and the coil spring mounts are diferent.
The cross members are different as one is used to hang the diff assembly from.
The floor plate beneath the rear seats / above petrol tank is different.
The actual petrol tank has a cut out for the propshaft on the 4wd version.
The tunnel has mountings for the propshaft supporting bearing (near the hand brake assembly) i got these off the s3 shell.
The innner wheel arches are different cos the 2wd shocks mount through the top of the inner wheel arch and the 4wd uses brackets from the wheel arch.
The rear seat mountings are different - im planning on a cage so never really looked into this but the S3 rear seat mountings are totally different. The originals could be removed from the 2wd inner arches and welded to the 4wd arches but not too bothered.
Everything else is just normal stuff, obtain a 4wd gearbox, complete back axle, propshaft etc.
When i get back from my 2 weeks away i am off for a whole week so i hopefully get the conversion finished and flood the thread with pics !
So long.
