Applemobile's White Cupra R32...Turbo? In car video added
Apr 12, 2008
1,197
Good to have it back. Although the plan is to take it back of the road at the end of the sumer for some more work.
gazcuprablk
my 300+ death box :)
Mar 31, 2006
858
south wales
hi m8 do you have any more pics of the engine bay? also where did you tuck/replace the wires as im doing the same to my ibiza but just trying to eliminate a few wires and make it a bit neater, im also going the same as you with the different colour bay to the body
Deleted member 60700
local hero wondered where this had gone, i used to pass u on way to work in marsh barton most days in my 306 glad to see it back mate
Apr 12, 2008
1,197
never have tucked the wires very well at all tbh! i completely removed un-nessisary ones, disconnected the earths and made new ones under neath the chassis rails. Then ran the loom underthe engine mount as apposed to above it as is stock. To do it properly you need to take the engine out, and extend some wires which i will be doing later this year. Its not technical work, its just a hell of a lot of work for a very subtle difference, you will realise this as soon as you start!
Apr 12, 2008
1,197
Something i had meant to do for a while. Make a sump guard! Its made out of 2mm steel and is bent in such a way to add strength and adds surprisingly a large amount of protection. The only thing that gets damaged still is my gearbox mount, but nothing can be done about that unfortunately.
Nov 24, 2007
543
Swansea
Holy car revival.
I was wondering where this Leon went to. Glad to see it back in action. Looking forward to see how it progresses.
Apr 12, 2008
1,197
May not look like i have done much, but i have :lol: I have completely removed all traces of Air\Con, because a/c is for fags. I have removed all appropriate wiring from the loom, and separated the lighting and screenwash, extended where necessary and ran that wiring down the inside of the wing. how this side of the engine bay looks now is basically how it will look, the PAS reservoir will be relocated down into the hole at the front under teh chassis leg, and the coolant resevoir will be removed completely. All brackets you can see will be removed and everything smoothed.
