Pretty good Rob. I think the Forge fmic probably remove a restriction somewhere. I recall you saying you would be more than happy with 320BHP?
Yeah the Forge FMIC really did
help it realise its potential.TBO its a bitter sweet, the first hybrid had so much potential to flow 340bhp but it was surging
This hybrid is pretty much maxed out to the b0llix, it literally cannot flow anymore.(if only we could get around the V1 hybrid surging, (stayed tuned
Boost is 1.8/9bar down to 1.4/5 at 7k rpm, duty cycles are just stupid high at this level, i.e the wastegate might as well be welded shut, still the EGT's are not to bad 930c region, which is acceptable IMO(highest with WMI was 840c!!)
Overall i am pretty happy, but the real test comes when i actually get it on a dyno to see how these calculations are translating to the wheels, if their decent i will be doing full write up for peeps regarding the hybrids, lessons learned etc....
In the mean time my WMI is still disconnected so i am lossing power through timing.I spend some time tonight drawing up a 15mm spacer to go between the Intake manifold and the TB, here it is: (rough sketch btw)
Also looking at Ronin225 RR and he did a sweet battery relocation to the boot, this is next for me as i want to get rid of that stupid S bend from MAP sensor pipe to the TB and just have a straight run, oh and it will be shiny
