Yeah it was probably roasting but what difference does it make really
there designed to work in those conditions and if there not they have no business in an engine bay.
i dont believe the spring is being effected by heat... its a formed spring and engine temps are no where near what they would be tempered at...
BUT
I do think springs once compressed will relax after initial use and settle.. which is the more likely cause for change to me
that video you posted above is exactly what I was describing to you... Great vid.. comfirms what happens when the nozzles too outboard of the hole its sat in.. The spray cone which is usually less than 90 degrees (and varies with manufacturer I might add) could catch the hole on the way out if not flush with the pipe ID, cause drop out.
Pheonominal Build and Phenominal car mate!
Some serious work gone into this and its certainly paid off!
Beautiful
Bill the guy can build practically anything you want, he can only be described as a seriously talented, he has a build thread over on Club GTI where he is rebuilding an engine, but most of the parts for the engine he has fabricated himself.
If you have an hour spare, this is well work a read
http://www.clubgti.com/forum/showthread.php?t=205299
I was shocked at how bad the silicone hose adapter performed too, just lets water/meth pour into the hose ... really bad!
this car is fooking awsome the best lcr on here by far i enjoy reading your thread and the will to keep up with it and paitent you have with it is a credit to you mate.
great work robbie, as wayne said your a credit to your self, but also you are helping others who want to do the same thing. i have learned a few tricks from you now, so it just shows you are a important member on this forum. and again as wayne said your car is one of the best here. keep up the good work m8.
