Not sure if other vag models fit matey. Maybe worth seeing how much the hubs are from a dealers and saving up? Or try a scrap yard for an
Ibiza with 288mm brakes on?
Not manny Ibizas in scrap yards here in Croatia. And even less with 288mm! Transition country - cars are cheap and weak or premium brands!
Even mine PD100 is not often! Lots of Ibizas but 1.2 or SDI. Guess that can be the answer for first question in your post also.
How can I find out catalog number or part number (english is not my native language so sorry if I missuse some words!) for cupra or PD130 hub?
That way I could check maybe numbers for other cars fit and we will have the ultimate answer for annybody else with same dilema in the future.
EDIT:
I have found some VAG part numbers. Hope that will
help anybody in the future.
For 312mm conversion you need:
Left brake caliper housing - 1UO 615 123
Right brake caliper housing - 1UO 615 124
Brake disc - 8NO 615 301A
Brake pads - 1JO 698 151M
Brake carrier with pad retaining ring - 1UO 615 125
Brake hoses (longer ones from vRS or TT) - 1JO 611 701G
If like me got no 288mm brakes you need also:
Wheel bearing housing left - 6QO 407 255S
Wheel bearing housing right - 6QO 407 256S
Wheel hub with bearing (72mm) - 6QO 407 621AJ
If someone notice that is incorect please make alarm so nobody buy wrong stuff! I am not sure is the third place in code ("O") letter "O" or it is number "0" (like "zero").
Thanks!
