Cold Start Engine Tapping?
Nov 15, 2010
1,364
Harrogate, England
Im getting quite a noise engine tapping on cold start up, nearly sounds like a diesel enging claking away, quiets down after about 45sec-1min, however I just dont think its normal, any suggestions anyone? Its the 1.4L 16V engine..
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Pershore, worcestershire
Sounds like the cam chain tensioner, a lot of the leons do this including mine, they usually stop after a couple of seconds, the tensioners are hydraulic and need to fill with oil its while this is happening that the tapping noise can be heard, its when the noise doesn't stop is when you need to worry. Reving it also helps.
Nov 7, 2009
858
What could happen if the you leave the tensioner? Iv jus had a full cambelt service including pullys etc anxd water pump. Would mine have been changed then or is it a diferent area?
Nov 15, 2010
1,364
Harrogate, England
The car has done 88k miles, it had the cambelt serviced/changed at 76k miles so I wouldnt have thought that was bad, but like I said it goes away after a short time, I will try revving the engine next time it does it to see if it goes away, and yes ive checked the oil just had a service 1k miles ago...
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
It can throw the timing out, this has happenbed to me and i have a nice new tensioner on my desk waiting for me to fit it. Mine keeps tapping away i need to drive down the road and stop the engine and start it again before it stops tapping, there is a little filter under the tensioner i am assuming this gets blocked and until the pressure builds up enough it stops the oil going into the tensioner.
Pyro
But this happens wether hot or cold he said in the title it's cold start but if you get it all the time the cam chain tensioner is a good bet but also carbon canester makes a tapping does it come from hear? If so then it cam chain thesioner ;)
Pyro
It has a seal that holds oil pressure and if this breaks then the ngine has to build the pressure back up wen you first start the car once presure is achieved then it stops ;) if it completely fooked then it can't active pressure ;)
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Carbon canister makes a ticking noise the tensioner makes the car sound like a diesel, also i think the cold weather could possibly make the oil thicker, so the tapping noise is more noticeable.
Pyro
Could well be mate ;) what side is the noise coming from?
Nov 7, 2009
858
Is this attached to the cambelt? Im gettin a not so good crackling sounding from round my drivers front wheel? Sound like sumthin is broke. Gettin on my tits as i dont like drivin my car wen it makes funny noises
Pyro
I'll get a vid of mine as it does it on start up give me 10 mins gents
Phillc
Love is....Yellow
Apr 23, 2007
4,170
20
Not you ya spoon :p I was asking the op ;)
:cartman: You did quote me though.
Is this attached to the cambelt? Im getting a not so good crackling sounding from round my drivers front wheel? Sound like something is broke. Gettin on my tits as i dont like drivin my car wen it makes funny noises
That could be the cam belt tensioner, not good if that goes, mega damage will follow.
Pyro
here we go its only about 2 seconds when it first starts up then it goes to its normal tappy sound ;) i got two the second one is a shorter sound as i had just driven to the kabab place :D
click to view
hope it helps
