LCR W.I.P Update K04 Hybrid- F23 Here, mini review page 50
t0m
LCR 225
Apr 29, 2007
8,133
7
Kent
Surfing around on my laptop i found these, i must post more car candy on this thread, pics are always nice to look at.
Mmmmm! I love your car so much Robbie. Looks stunning in those pics. Very well tuned LCR.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Thanks t0m, us Platinum grey owners have exceptional taste, LOL.
On another note, i am plagued by this error it has only come on the car since going to stage 2, evertime i get it my mapper does a few tweaks, its disappears for a few weeks andt then comes back, its also accompanied by a fuel cut so i have to cycle the ignition which is much fun on an open run :-(
any ideas lads?
17743 - Engine Torque Monitor 2:
Control limit Exceeded : P1335
0035 35-10 - - Sporadic
Its doing my head in and i am afraid to let the missus drive the car, cause she won't have a clue what to do if it happens and it could cause an accident.
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
he needs to move the torque limit up in the map
Thats what i thought, is there anyway i can do this myself or even read the value myself?, i do have the facility to download/upload new maps to my car.
Is it an excessive amount of torque, it hit 330lb/ft on the dyno before and we have tweaked again since then.
take it is a custom map, it sounds like the touque to me
Yeah, custom if there's such a thing LOL.
brad1
I've probably read before but can't be assed to look back through lol, are you on standard clutch still or do you have an uprated one?
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Still standard(touch wood). I dont do power starts or rev to 3,000 rpm and then dump the clutch and the standard one has held out.I would say its on the limit though, i already have a new one lined up, just in case.
ibizacupra
Jack-RIP my little Friend
Jul 25, 2001
31,333
19
glos.uk
I dont think you can access it or alter it other than in the map itself.
part throttle type boost from low rpm?
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Yep, part throttle usually in higher gears, like going round a roundabout in 3rd and then putting the foot down on the exit, thats when she cuts.
My mapper sent me a new map file this morning so i loaded it up to the car and haven't see the error yet, so touch would.
I can post the logs if you like to compare Bill, there all 4th gear runs but i couldn't go much above 6k rpm.;)
ibizacupra
Jul 25, 2001
31,333
19
glos.uk
cool.. had the same on wellys on an early file.. the turbo was getting going far faster than the map was expecting at that point.
logs would be nice to see :thumbup:
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Logs, all done in 4th gear, this was a new file i loaded today, it doesn't seem to be running as much boost as Welly's.Also i need to add the requested fueling to the graph, it only shows actual at the moment.
Code:
Group A:	'002				Group B:	'020
	RPM	Load	Inj. On Time	Mass Flow		Idle Stabilization	Idle Stabilization	Idle Stabilization	Idle Stabilization
TIME					TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 CF	 CF	 CF	 CF
0	1680	34.6	2.38	11.58	0.3	0	0	0	0
0.61	1720	35.3	2.72	11.64	0.9	0	0	0	0
1.21	1760	33.8	2.72	11.64	1.51	0	0	0	0
1.82	1760	29.3	2.38	10.31	2.12	0	0	0	0
2.42	1800	24.8	2.04	8.33	2.71	0	0	0	0
3.01	1800	22.6	1.7	7.58	3.32	0	0	0	0
3.62	1800	21.8	1.7	7.44	3.93	0	0	0	0
4.23	1800	21.8	1.7	7.61	4.52	0	0	0	0
4.83	1840	21.1	1.7	7.47	5.14	0	0	0	0
5.43	1840	21.8	1.7	7.94	5.74	0	0	0	0
6.04	1840	24.1	2.04	9.22	6.33	0	0	0	0
6.64	1880	42.1	3.4	16	6.95	0	0	0	0
7.25	1960	41.4	3.06	16	7.55	0	0	0	0
7.85	2040	75.2	5.78	33.42	8.15	0	0	0	0
8.44	2200	97	7.14	43.39	8.76	0	0	0	0
9.06	2400	112	8.5	55.92	9.35	0	0	0	0
9.65	2680	132.3	10.2	75.08	9.96	0	0	0	0
10.27	3000	175.2	13.26	117.11	10.57	0	0	0	0
10.87	3440	191.7	17.34	185.14	11.17	0	0	0	0
11.47	3920	191.7	18.02	176.69	11.77	0	3	0	0
12.08	4440	191.7	18.7	193.11	12.38	0	3	3	0
12.68	4880	191.7	18.36	209.33	12.98	0	3	3	0
13.28	5440	191.7	18.36	228.69	13.59	0	3	3	0
13.89	5720	191.7	17.68	231.06	14.19	0	2.3	3	0
14.49	6080	191.7	17.68	245.31	14.79	0	2.3	2.3	0
15.09	6400	191.7	15.3	241.03	15.41	0	0	0	0
15.7	5560	13.5	1.36	4.53	16	0	0	0	0
16.3	4480	14.3	1.36	9.11	16.6	0	0	0	0
16.9	4480	10.5	0	9.25	17.21	0	0	0	0
17.51	4760	12.8	0	11.78	17.8	0	0	0	0
18.11	4680	12	0	11.06	18.4	0	0	0	0
18.71	4640	12.8	0	11.39	19.02	0	0	0	0
19.32	4560	12	0	10.58	19.62	0	0	0	0
19.92	4480	12.8	0	10.28	20.22	0	0	0	0
20.52	4400	12	0	10.22	20.83	0	0	0	0
21.13	4360	12.8	0	10.92	21.42	0	0	0	0
21.73	4280	11.3	0	9.86	22.02	0	0	0	0
22.34	4240	12	0	10.69	22.64	0	0	0	0
22.94	4160	12.8	0	10.56	23.24	0	0	0	0
588.42	720	23.3	1.7	3.31	588.72	0	0	0	0
589.02	760	22.6	1.36	3.25	589.32	0	0	0	0
589.62	800	28.6	2.38	5.86	589.93	0	0	0	0
590.23	1360	36.8	3.06	11	590.54	0	0	0	0
590.83	1320	48.1	3.74	12.83	591.14	0	0	0	0
591.43	1280	54.9	4.08	14.61	591.74	0	0	0	0
592.05	1160	57.9	3.74	13.42	592.34	0	0	0	0
592.64	1560	60.2	4.42	18.89	592.94	0	0	0	0
593.25	2040	63.9	4.42	25.14	593.55	0	0	0	0
593.86	2480	65.4	4.08	31.69	594.16	0	0	0	0
594.46	2960	69.2	4.76	40.92	594.76	0	0	0	0
595.06	3520	76.7	5.1	55.33	595.37	0	0	0	0
595.67	3880	40.6	2.72	19.72	595.97	0	0	0	0
596.27	3240	16.5	1.36	7.58	596.57	0	0	0	0
596.87	2600	16.5	1.36	7.72	597.16	0	0	0	0
597.48	2080	52.6	5.44	28.53	597.77	0	0	0	0
598.07	1400	86.5	6.46	23.58	598.38	0	0	0	0
598.67	1480	91	6.8	27.33	598.98	0	0	0	0
599.28	1600	94.7	7.14	30.25	599.59	0	0	0	0
599.88	1680	98.5	7.48	34.22	600.18	0	0	0	0
600.48	1800	100.8	7.82	36.47	600.79	0	0	0	0
601.09	1920	105.3	8.5	42.08	601.39	0	0	0	0
601.69	2040	115	8.84	47.61	602	0	0	0	0
602.29	2200	124.1	9.18	55.81	602.61	0	0	0	0
602.91	2360	131.6	9.86	62.94	603.21	0	3	3	3
603.51	2520	147.4	11.22	77.44	603.81	0	3	3	3
604.12	2680	173.7	12.92	100.61	604.41	0	2.3	3	3
604.72	2920	191.7	17	133.11	605.02	0	2.3	2.3	3
605.31	3200	191.7	17.68	144.25	605.62	0	2.3	2.3	2.3
605.93	3480	191.7	16.66	149.42	606.23	0	2.3	2.3	2.3
606.53	3720	191.7	16.66	155.89	606.83	0	1.5	2.3	2.3
607.13	4000	191.7	17.68	162.19	607.43	0	1.5	1.5	1.5
607.74	4280	191.7	17.68	175.92	608.04	0	1.5	1.5	1.5
608.34	4520	191.7	18.36	191.19	608.64	0	3.8	4.5	1.5
608.94	4840	191.7	18.36	208.86	609.25	0	3.8	4.5	1.5
609.55	5080	191.7	18.36	219.47	609.85	0	3.8	4.5	0.8
610.15	5320	191.7	18.36	226.28	610.45	0	3.8	4.5	0.8
610.75	5560	191.7	18.02	235.61	611.06	0	3	3.8	0.8
611.36	5760	191.7	18.36	238.14	611.66	0	3	3.8	0
611.96	5960	191.7	17.34	238.14	612.26	0	3	3.8	0
612.56	6160	191.7	17	240.75	612.87	0	2.3	3	0
613.17	5920	13.5	1.36	0	613.47	0	0	0	0
613.77	4880	14.3	1.36	9.83	614.07	0	0	0	0
614.37	4000	11.3	0	7.17	614.68	0	0	0	0
614.97	3600	11.3	0	8.19	615.27	0	0	0	0
615.58	3680	11.3	0	8.14	615.87	0	0	0	0
616.18	4200	11.3	0	9.39	616.48	0	0	0	0
616.79	4240	12.8	0	12.5	617.08	0	0	0	0
617.39	4160	12.8	0	9.89	617.68	0	0	0	0
617.99	4080	12.8	0	9.06	618.29	0	0	0	0
618.59	3880	12.8	0	9.5	618.9	0	0	0	0
619.2	3680	12.8	0	9.78	619.5	0	0	0	0
619.8	3520	12.8	0	8.86	620.1	0	0	0	0
620.4	3440	14.3	0	9.47	620.71	0	0	0	0
621	3400	12	0	8.5	621.32	0	0	0	0
621.62	3360	13.5	0	9.19	621.91	0	0	0	0
622.22	3320	13.5	0	9.06	622.52	0	0	0	0
622.82	3280	12	0	7.83	623.12	0	0	0	0
623.42	3200	13.5	0	8.58	623.72	0	0	0	0
624.02	3200	15.8	1.36	9.22	624.33	0	0	0	0
Code:
Group A:	'115				Group B:	'112
	RPM	Load	Absolute Pres.	Absolute Pres.		Temperature	Load
TIME					TIME
STAMP	 /min	%	 mbar	 mbar	STAMP	°C	%
0.29	2200	27.8	990	1000	0	560	0
0.9	2200	28.6	990	1000	0.6	560	0
1.51	2240	27.8	990	1000	1.2	560	0
2.1	2240	32.3	990	1000	1.81	565	0
2.71	2320	50.4	990	1010	2.4	565	0
3.32	2520	66.2	1050	1070	3.02	565	0
3.91	2720	64.7	990	1140	3.62	570	0
4.53	2880	54.9	990	1090	4.22	575	0
5.13	2800	16.5	990	1070	4.83	580	0
5.72	2360	15.8	990	1030	5.43	590	0
6.33	1640	78.2	1710	1000	6.03	595	0
6.93	1720	89.5	1730	1070	6.63	600	0
7.55	1840	94.7	1800	1140	7.24	600	0
8.14	1960	101.5	1870	1210	7.84	605	0
8.74	2080	110.5	1890	1300	8.44	610	0
9.34	2240	120.3	1960	1390	9.04	620	0
9.95	2360	129.3	2020	1520	9.65	625	0
10.55	2560	144.4	2090	1670	10.26	630	0
11.15	2720	174.4	2110	1970	10.86	640	0
11.76	2960	191.7	2120	2470	11.46	660	0
12.37	3240	191.7	2210	2540	12.07	675	0
12.98	3520	191.7	2320	2480	12.67	695	0
13.58	3760	191.7	2410	2450	13.28	735	0
14.18	4040	191.7	2500	2430	13.88	765	0
14.79	4320	191.7	2550	2450	14.48	775	0
15.39	4560	191.7	2550	2480	15.09	790	0
15.99	4840	191.7	2550	2490	15.69	805	0
16.6	5080	191.7	2550	2490	16.3	815	0
17.2	5320	191.7	2550	2470	16.9	815	0
17.8	5560	191.7	2550	2450	17.5	820	0
18.41	5760	191.7	2550	2490	18.11	820	0
19.01	5960	191.7	2550	2480	18.71	825	0
19.61	6200	191.7	2550	2420	19.31	835	0
20.22	6000	15	990	1990	19.93	845	0
20.82	4960	14.3	990	1150	20.52	855	0
21.42	4080	11.3	990	1070	21.12	855	0
22.03	3280	12.8	990	1030	21.73	840	0
22.62	2560	12	990	1020	22.32	815	0
23.23	1920	13.5	990	1010	22.92	790	0
23.83	1360	15.8	990	1000	23.53	765	0
24.43	1160	15	990	1000	24.14	735	0
25.04	1000	16.5	990	1000	24.73	715	0
Code:
Group A:	'115				Group B:	'031
	RPM	Load	Absolute Pres.	Absolute Pres.		Lambda Factor	Lambda Factor
TIME					TIME
0	1840	12.8	990	1000	0.3	1.99	1.05
0.6	1800	14.3	990	1000	0.91	1.99	0.95
1.22	1800	41.4	990	990	1.52	0.95	0.95
1.81	1840	84.2	1800	1020	2.12	0.98	0.96
2.41	1960	94	1850	1120	2.73	0.94	0.95
3.02	2080	105.3	1900	1240	3.32	0.94	0.95
3.63	2200	117.3	1960	1350	3.92	0.95	0.95
4.23	2360	126.3	2020	1470	4.54	0.95	0.95
4.83	2520	142.1	2090	1620	5.14	0.94	0.95
5.44	2720	170.7	2110	1900	5.73	0.96	0.95
6.05	2920	191.7	2130	2400	6.35	0.95	0.95
6.65	3200	191.7	2210	2520	6.95	0.94	0.95
7.25	3480	191.7	2310	2480	7.55	0.92	0.93
7.86	3760	191.7	2400	2460	8.16	0.92	0.92
8.46	4040	191.7	2490	2420	8.76	0.91	0.9
9.06	4280	191.7	2550	2440	9.36	0.88	0.87
9.67	4520	191.7	2550	2490	9.97	0.84	0.85
10.27	4800	191.7	2550	2510	10.57	0.84	0.84
10.87	5080	191.7	2550	2490	11.17	0.84	0.84
11.48	5320	191.7	2550	2500	11.78	0.84	0.84
12.08	5560	191.7	2550	2500	12.38	0.83	0.84
12.68	5800	191.7	2550	2500	12.99	0.84	0.84
13.29	5960	191.7	2550	2470	13.59	0.84	0.84
13.89	6160	191.7	2550	2420	14.2	0.89	0.91
14.49	6160	11.3	990	1560	14.8	0.75	0.94
15.1	5960	14.3	990	1140	15.4	1.97	1.05
15.7	5640	9.8	990	1060	16	1.99	1.05
Code:
Group A:	'002				Group B:	'011
	RPM	Load	Inj. On Time	Mass Flow		RPM	Temperature	Temperature	Ign. Timing
TIME					TIME
STAMP	 /min	%	 ms	 g/s	STAMP	 /min	°C	°C	°
0	760	22.6	1.7	3.31	0.31	720	98	24	1.5
0.6	760	22.6	1.7	3.31	0.91	1000	97	24	18
1.22	1360	57.1	4.76	16.28	1.51	1400	97	24	11.3
1.81	1360	60.2	4.42	16.28	2.11	1200	98	24	17.3
2.41	1120	69.9	4.76	15.61	2.72	1360	98	24	16.5
3.03	1640	77.4	5.78	27.83	3.33	1960	97	23	18
3.63	2360	85	6.12	44.69	3.93	2760	98	22	24.8
4.23	3120	94	6.8	60.97	4.54	3360	98	21	32.3
4.84	3240	15	1.36	3.44	5.13	3000	98	21	20.3
5.45	2720	15.8	1.36	7.11	5.73	2480	98	21	33
6.04	1760	78.2	6.12	31.58	6.34	1280	98	22	10.5
6.64	1320	86.5	6.46	22.97	6.94	1360	98	21	12
7.24	1400	88	6.46	25.64	7.54	1440	98	21	12.8
7.86	1520	91.7	6.8	26.75	8.15	1560	98	20	12
8.45	1600	94.7	6.8	31.03	8.76	1640	98	20	12
9.05	1720	97	7.14	32.19	9.35	1760	98	19	13.5
9.67	1840	98.5	7.48	35.72	9.96	1880	98	18	13.5
10.26	1920	103	7.82	39	10.56	2000	98	18	14.3
10.86	2080	110.5	8.16	45.92	11.17	2160	98	18	12.8
11.47	2200	120.3	8.84	53.39	11.77	2280	98	18	12
12.08	2360	130.8	9.52	62.19	12.37	2440	99	18	13.5
12.68	2520	139.8	10.2	71.53	12.99	2600	99	18	9.8
13.29	2720	162.4	12.24	93.58	13.58	2800	98	18	0
13.89	2880	191.7	15.3	128.22	14.19	3040	98	18	2.3
14.49	3160	191.7	17	139.06	14.8	3280	98	18	4.5
15.1	3440	191.7	16.66	144.39	15.4	3560	98	18	6
15.7	3680	191.7	16.66	155.92	15.99	3840	98	18	6.8
16.3	3960	191.7	16.66	163.97	16.61	4080	98	18	10.5
16.91	4200	191.7	17	170.89	17.21	4360	98	17	12
17.51	4440	191.7	17.34	188.58	17.8	4600	98	17	12.8
18.12	4760	191.7	17.68	196.53	18.42	4880	98	18	14.3
18.72	5000	191.7	17.68	208.19	19.02	5120	98	18	12
19.32	5240	191.7	18.02	220.5	19.62	5360	98	18	12.8
19.93	5480	191.7	18.02	229.75	20.23	5600	98	18	15
20.53	5680	191.7	17.68	231.39	20.83	5800	98	20	15
21.13	5920	191.7	17.34	238.5	21.43	6040	98	21	12
21.74	6120	191.7	17	240	22.04	6200	98	21	12
22.35	6320	191.7	16.66	239.28	22.64	6320	97	21	-7.5
22.94	6120	12.8	1.36	20.94	23.25	5520	97	17	5.3
23.55	5040	14.3	1.36	7.69	23.85	4600	97	15	3.8
24.15	4160	12.8	0	8.81	24.45	3720	97	15	3
24.74	3320	11.3	0	6.47	25.05	2920	97	15	1.5
25.35	2520	13.5	0	5.78	25.66	2160	97	16	-3
25.95	1800	13.5	0	4.67	26.25	1480	97	17	0.8
26.56	1920	14.3	0	4.39	26.86	2640	97	18	1.5
27.17	3720	12	0	8.78	27.47	3640	97	18	20.3
27.76	3600	12.8	0	9.19	28.07	3600	96	18	3
28.38	3560	12.8	0	9.56	28.67	3520	96	18	3
28.97	3520	12.8	0	8.39	29.28	3480	96	18	2.3
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Just a little update, we are still working the remap for this car, its on version 8.1 at the moment, so that will give you an idea of the work going into tuning it.I feel it is practically there TBO and will perform well on the Dyno.Now all i need is Bills 3" TIP to really compliment the setup.
Here is my lastest mod, not your usual one and no its not a photoshop jobby, although i did blur out my VIN number for obvious reasons.
Can anyone spot what was done?LOL
rsmith
Robbie
Apr 28, 2004
2,797
Tipperary, Ireland
Here is my latest boost log, this hybrid can really push it out, you cannot see it on the graph as the OEM MAP sensor can only read to 1.5bar.Mine peaks straight to 1.7 then gradually declines until 1.5 at 5000rpm and 1.45 by readline
