Yes, with the cable i linked before, however some members altered certain files so that the software would not send information out to Ross-tech. I found simply turning off wifi and disabling it did the job. Do it before you install the software. Also with the older versions (I used 704.1), change the system clock of the netbook/laptop to 01/04/2007 so there are no problems.
I would download version 704.1 rather than use the software on the cd provided as some members found that the later versions did not work with the cable. As I said in the previous page, on the website with ships and pirates
When you have done that, start your car, or turn the ignition, plug in the cable for 30 seconds, then plug the cable into your netbook after those 30 second. Start up the software, and it will
help you use it by giving you bubbles of what to do.
