Should just be able to clean them and just lacquer an it brings them out red again according to the refurb guides. Use te car every day though so not sure when itl happen!
Yeh like a low boost base map to bed it in? Itl be able to take some abuse once it's bedded the rings in etc mind!
You having the limiter raised? Itl be able to take it no problem now the valves are swapped out for decent ones
robbie the liquid gauge does that too. get one there meant to be really good ,
i got mine to keep and eye on things till i get map sorted, with the water meth what egt you been getting?
I did 6 power runs the other night one after the other, so on the last one i monitored the EGT's max i seen was 860c which is good IMO.
thats very good yeah, what % of water meth you using on them runs?
i got told best to start with a 20 % meth start, what did you start on?
ok mate cheers, was told today if not used properly can actually bog the engine down, did you have this problem at all?
ok so in theory on motorway driving off boost the water meth should not be being used ?
and what power figures you hoping for
