Sorry, did have the car on the dyno last Friday just to do some logs and see whats what (thanks Bill) and there are a few things to sort out.... Firstly there didn't appear to be any preload on the actuator and the actuator itself is a higher rated one that I had on previously and I was getting boost creep at high revs.... I adjusted this and hoping the actuator will go a bit softer (which they do) after a little while... using the softer of the 2 springs on the UNOS and getting a steady 1.5 bar but.... did a check on the boost pre FMIC and after (manifold pressure) and there is quite a drop... some can be attributed to the FMIC itself which is normal but a little higher than expected but there is a big difference at lower RPM as the turbo spools.... Bill has all the logs and the figures etc so I cannot really say much more than that at the moment but one thing he does think is an issue is I could be losing boost through the DV initially then after its caught up with itself all is better... so I have now fitted a white spring (red in there before), Bill had to do this to Indies Leon recently... haven't tested this yet though...
Bill also found that I was getting no timing pull so dialled in more timing advance and was upping the power all the time until the ECU had a paddy and pulled 11's!!!! not good!
So just reset back to 0 additional advance (over what the map has) and going to start again... the fuelling isn't too bad, wideband lambda helps out a bit here too... it is going very rich at high RPM though killing the power which is a shame... this could well be map related...
Basically spent the afternoon gathering data to see where the map needs tweaking and to see why power is still a little off... few more things to try bearing in mind the map wasn't quite finished before and I have changed quite a bit of the engines characteristics now with the large port head and larger turbine etc so its to be expected...
Car is running ok normally although a little iffy under boost atm... didn't show so much on the dyno but on the road its noticable... back on actuator pressure with a bit of boost creep... should have ported the wastegate while the turbo was off really but during the dyno tests the boost didn't go above 1.5ish bar anyway so thats prob where it will end up so not so bothered... if it becomes a prob or I am in a position where the head needs to come off again then I will look at sorting the wastegate then..
This week has been a bit of a write off tbh as my daughter has dislodged her knee cap and the missus is out most evenings so not been down the unit much plus Bill has a bit of work on so as the car is running ok I am happy to wait until he has 5 mins to have a go at the mapping...
Couple of shots of the engine bay with the SFS hose fitted...
<tuffty/>
