Correct, hazards flash for about 10secs as it thinks your having an accident
don't you have to be going at a really fast speed and slam on so the ABS is on for at least 2 seconds? I imagine it'd be hard to test out, wouldn't fancy volunteering
Hi guys i wonderd if one of you can help im trying to disable the seat belt chime but im not 100% sure what value i need to change and what to, here is a screen shot of the screen from vag com
I did this the other day for Scott. Its the top number that you see 0006401 change that to 0000401 and then hit Do It!
Alex
Thanks Alex it wont effect anything else will it? Just disable the seat belt
Does anybody know what Measuring Block is best for logging Boost Pressure Actual versus Requested?
ive just flicked through them but couldn't see one that said actual and requested
i just got a load that said mbar Absolute
115 Gives readings nothing to do with Boost! its like voltage or something
Not me
Ive flicked through Channels 0-200 and i dont see a single one that mentions Specified and Actual
using the VCS 811.2 BETA
