Leon 1P Vag-Com Cable ** Canbus OBD Diagnostics**
rikwandi
52
The Hague, Holland
When i took my Leon to SEAT the other week to get valued, the salesman asked if it was a non standard alarm. I just told him a different garage activated the beeps, so he didnt think i had been messing with it.
And for anyone who is interested, i still have my cable for sale.
Interested on your cable. Tried send you PM but seemed you are running out of the quota there...
Contact me as you will.
Irvan
IanG
264
I can't connect to 46 too.
My car is a Leon FL 2010 1.8TSI DSG and my version is 908.
:help:
After a little digging there is no Module 46 on the Facelift Leon it's under Module 9 Central Electrics.
However still no further forward as I haven't got a clue what each of the Bytes are under Module 9 as the Long Coding Helper says it has no data for my ECU.
I'll get there but it might take a little time :think:
tt28
Got the same issue. Going to try and take a look over the weekend and work out whats what.
DanGB
Who need's a Diesel....
Feb 12, 2006
3,772
London
the label files havent been updated yet, have you tried the latest version of software?
st@rgixxer
GSXR Junkie!!!
Mar 27, 2010
58
Edinburgh
vag.com troubles
hey guys,
Got my cheapo cable from aforementioned website, and had a go this evening.
Using versions 7041 and 0823, I can scan and read fault codes (after disabling wireless connection and changing date), but I cant clear the faults or edit any settings, it comes saying 'needs a licensed verion of this software'.
Anybody have any clues???
Fault codes as follows, and it doesnt mean anything to me...!
VAG-COM Version: Release 704.1
Data version: 20070422
Sunday,01,July,2007,20:25:58:26365
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: xxxxxxxxxxxxxxxxxxxxxxxxxxx
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door,Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: Sporadic communication error 1000
Address 01: Engine Labels: None
Part No SW: 03G 906 018 DT HW: 03G 906 018 DT
Component: R4 2.0l PPD1.2 G 0231
Coding: 0050072
Shop #: WSC 06441
No fault code found.
Readiness: N/A
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Coding: 0006786
Shop #: WSC 06441
Address 08: Auto HVAC Labels: 1K0-907-044.LBL
Part No: 1P0 907 044
Component: ClimatronicPQ35 010 0502
Cheers Muchly, Kev.
AndrewJB
Aug 16, 2007
11,209
485
Maranello
you can go into each module that shows an error and clear them individually! then it will scan that module again if it comes back up it means its current
st@rgixxer
GSXR Junkie!!!
Mar 27, 2010
58
Edinburgh
It doesnt let me clear them, just comes up with the warning that its not a licensed copy.
Also doesnt show the balloon with the list of options to edit settings.
Am I being stupid???
Jun 5, 2008
511
Leeds
Well I ended up sending back my cable I bought As I couldn't get it to work. After messing around I managed to get a new 908 cable and software delivered from a chap in the uk for 42.50 and this works a treat. Now have all the labels and can do everything now. So if people are having a problem with the 704 cable i suggest you upgrade to a 908 one
AndrewJB
Aug 16, 2007
11,209
485
Maranello
Anybody know what Channel it is to test boost pressure?
i was told 115 so i go onto my 811.2 BETA VCDS and 115 has got voltage or something on it
and i carnt find a Boost Actual and Boost Specified Anywhere
Sep 5, 2009
569
Midlands
The cable arrived yesterday and after a good play about with it it works perfectly, make sure your wireless is turned off while your plugged in and away it goes with the supplied VCDS version 805, wicked bit of kit for £25 can't fault it!!
campbell_p30
125
Belfast
Visit site
For the struts:
Go to:
www..strutsdirect.co.uk/components/fixed-force-gas-struts-sd02-range.php?products_id=1080
[0] Gas Strut Type: Fixed Force Gas Strut - F-SD02-200
[1] Force N (Newtons): **Between 500-550NM**
[2] Rod End Fitting: Steel Ball - SBJ7
[3] Tube End Fitting: Steel Ball - SBJ7
[4] Rod End Bracket: Not requiered
[5] Tube End Bracket: Not requiered.
Total should be £35.72, £6.96 P+P, £7.47 VAT = £50.14
The combination of the strut length along with the end fittings, makes the struts prefect size for size of our standard ones.
I suggest people wait and see how i get on with the 520NM struts, hopefully they will be ok.
Ross27 - How did you get on with the 520NM struts? I'm still looking to do this mod.
ross27
Mazda 3 MPS
Mar 22, 2009
363
Glasgow
They were perfect for the two days i used them. I sold my car and sold the struts to a guy in Denmark i think it was MadsenTDI. So you may be best to ask him how he got on with them.
